I am using
RV220w router firmware 1.0.1.0
I can connect to the SSL VPN server using XP,windows 7 and window 2003 all 32bit stack 1. When I go to use windows 7 Prof. 64 bit IE v8 it will not connect. I dont even get where the laucher install. I get the error Please enable active X or make sure your site is trusted. All of this has been set yet it will not work. I also get the following error
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Win64; x64; Trident/4.0; .NET CLR 2.0.50727; SLCC2; .NET CLR 3.5.30729; .NET CLR 3.0.30729)
Timestamp: Wed, 25 May 2011 18:00:28 UTC
Message: Object required: 'VPLaunch1'
Line: 212
Char: 1
Code: 0
URI: https://unionchapel.us/scgi-bin/userPortal/sslvpnclient64?launch=true&is64bit=true
the source code is ref. line 212
