Catalyst 3550 MPLS VRF Problem
mesuti
Level 3
Level 3
hi,
I was trying to configure MPLS VPNs on Cat 3550, but I experienced some problems. When I create 2 or more VRF, I get too many packet losses on those VRFs. So without any VRF it works fine, when I add a VRF it again works as it is supposed to work. But after I add second one I get packet loss and no VRF works even the first one that worked. I made too many tests I cleared the first VRF then the second one worked ( because there is only one VRF). Strange problem huh?
I tried two ios versions but none was successful.
If you had a similiar problem please help me.
regards,
Mesuti
b.hsu
Level 11
Level 11
check out the following link for troubleshooting MPLS Based VPNs :
http://www.ciscopress.com/articles/article.asp?p=391649&seqNum=5&rl=1
