CCNA Lab Serial WAN connection
JAdams71
I am working on my CCNA and I have a small R&S lab setup with 2 1841 routers, 1 2811 router. The issue I am running into is all my routers have T1 DSU/CSU cards and I need to be able to simulate a serial WAN connection for labs. Is there a way to do this with the T1 cards or do I need to purchase serial cards and the DTE/DCE cables?
all you need is a T1 crossover cable, if you don't have one, you can make one yourself:
https://www.freeccnaworkbook.com/blog/ccna/how-to-make-a-t1-crossover
Then configure the interfaces as below:
R1
interface Serial0/0
description BACK-TO-BACK T1 CONNECTION - CSU/DSU LINK 1544KBPS
service-module t1 timeslots 1-24
service-module t1 linecode b8zs
service-module t1 framing esf
service-module t1 clock source internal
R2
interface Serial0/0
ip address 192.168.1.2 255.255.255.0
service-module t1 clock source line
R1
interface Serial0/0
R2
interface Serial0/0
Georg,
Thank you for your reply. I have the crossover cables so I will give your solution a try. I was trying to set the clock rate on one interface for it work as the DCE side like you would with a serial connection and the DTE/DCE cable and that would not work.
it should work. The important thing is to make sure that one side uses the line as the clock source, while the other uses 'internal'.
Thank you for your help. I was finally able to get around to testing it and I have connection between both routers on the t1 interfaces now.
