Change the AD of an EIGRP default route
jsinsabaugh
Could anyone give me some advice for changing the AD of only an EIGRP distributed default route? I've tried setting up an access list but I end up changing the AD of all routes under the EIGRP process.
2 Accepted Solutions
Hello
One example, to manipulate eigrp admin distance is if you have dual paths to the same network, if is what your  asking please see example?
R1 has two routes to network 2.2.2.2  advertised by 10.1.1.2 & 10.1.1.3 routers.
sh ip route eigrp
     2.0.0.0/32 is subnetted, 1 subnets
D       2.2.2.2 [90/156160] via 10.1.1.3, 00:01:24, FastEthernet0/0
                [90/156160] via 10.1.1.2, 00:01:24, FastEthernet0/0
access-list 10 permit 2.2.2.2
router eigrp 100
distance 91 10.1.1.3 0.0.0.0 10
R1#sh ip route eigrp
D       2.2.2.2 [90/156160] via 10.1.1.2, 00:16:43, FastEthernet0/0
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
You could use bgp backdoor command to increase AD of eBGP prefix to 200.
http://www.ccietalk.com/2008/07/23/bgp-backdoor-routes
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
5 Replies 5
blau grana
Level 7
Level 7
You can change distance on per prefix basis for internal EIGRP routes, but this is NOT possible for EIGRP external routes. Foer external routes, you can change distance for all prefixes or none.
I assume that default route is EXTERNAL route.
Best Regards
Hello
sh ip route eigrp
router eigrp 100
res
Paul
Thanks.
Kind Regards
Paul
Thanks Paul - I was doing my access list incorrectly
Here was the solution
access-list 10 permit 0.0.0.0
router eigrp 10
network 10.192.5.0 0.0.0.255
network 172.22.0.8 0.0.0.3
distance 15 172.22.0.9 0.0.0.0 10
#show ip route eigrp
D*    0.0.0.0/0 [15/26880512] via 172.22.0.9, 00:06:15, Tunnel113
I just wanted to bring down the AD of that route to beat the one BGP is advertising. Thanks again.
Best Regards
Could anyone please tell me what is the different between these two commands under the router eigrp section?
summary-metric 0.0.0.0/0 distance 250
distance 250 0.0.0.0 255.255.255.255
Thank you very much.
