changed question
bHubTel1610c
updated question
2 Accepted Solutions
ictunit12
You need to configure the vty lines on one of the routers, so that you can either telnet or ssh to it.
On one of the routers, enter the following from global configuration mode, (router would be your router hostname):-
router#(config) line vty 0 15
router#(config-line) password cisco
router#(config-line) login
Save this and it should allow you telnet from one router to another.
Cheers
Andy Dabell
Just access the first router in the normal way then use the telnet or ssh command to access the second router.
ictunit12
Cheers
Andy Dabell
