Cisco 1811 Router in remote location reach Server but Client Couldn't
reachrahaman
Let first have the Network Diagram.
1. I?m having Cisco 2821 Router in Head Office which serving 4 Branch Office with Cisco 1721 Router in MPLS VPN Cloud.
2. Right now I?m having a Remote Location which is connected using Wimax Technology using Cisco 1811 Router.
3. From Remote Router I can access the server in Head Office, where a local client in Remote Location couldn?t able to reach server. Hope there is Routing is missing.
4. Perhaps nothing to with Head Office Router because it serving other Branch Office without any problem.
5. Kindly provide the necessary Information as soon. Waiting for you all for your feedback.
RUNNING CONFIGURATIONS
interface FastEthernet0.3429
description FastEthernet 0.3429 dot1q vlan id=3429. By VPNSC: Job Id#=8134
encapsulation dot1Q 3429
ip address 172.31.2.154 255.255.255.252
ip nat outside
ip virtual-reassembly
no snmp trap link-status
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2
interface Vlan1
ip address 192.168.1.2 255.255.255.0
ip nat inside
interface Async1
no ip address
encapsulation slip
router bgp 64659
no synchronization
bgp log-neighbor-changes
neighbor 172.31.2.153 remote-as 65000
no auto-summary
Hoping best
Abdul Rahaman
Wow. Good catch. At first i was startled by BGP too - because local AS would be in AS Path. But since all routing information is provided by the provider, it's not a problem.
I think the problem can also be solved by injecting a route into ISP cloud, if ISP allows it.
Method 1.
Call ISP, and ask them to add route 192.168.1.0/24 to the next hop of 172.31.2.154.
After the route 192.168.1.0 shows in the "show ip route" in the HQ, remove "ip nat inside" and "ip nat outside" statements on the REMOTE router.
Method 2. (Configure BGP yourself)
HQ:
router bgp 64659
neighbor 84.235.77.85 allowas-in 1
Remote:
no ip nat outside
interface Vlan1
no ip nat inside
router bgp 64659
network 192.168.1.0 mask 255.255.255.0
9 Replies 9
Richard Burts
Abdul
There are several things that could produce the symptoms that you describe and we do not yet have enough information to know which it is.
It might be that the client at the remote site does not have a correct configuration of default gateway. Can the client at the remote site access any resource not on its local LAN? Can someone check and verify the configuration of the default gateway on the client?
If the remote router can access the server it would indicate that the remote router does have a route to the subnet of the server. But it is possible that the router at the HQ does not have a proper route back to the subnet of the client. One way to check this would be to use extended ping from the remote router. In the extended ping specify the server as the destination and specify the client LAN interface as the source.
It looks like this is a VPN connection and it might be possible that there is an MTU issue with the client accessing the server due to frame size issues. Are you doing anything in the config to control frame size or to reset the DF bit?
If you can clarify these we may be able to help find the cause of this problem.
Rick
Rick
1.
Client has the IP Address as IP: 192.168.1.50 SM: 255.255.255.0 GW: 192.168.1.2 (Which is Vlan 1 IP Address in Cisco 1811 Router)
2.
Exactly HQ does not have route back to subnet of Remote
HQ :
AL-AYUNI-OLAYA#sh ip route
Gateway of last resort is not set
B 50.0.0.0/8 [20/0] via 84.235.77.85, 05:38:35
84.0.0.0/30 is subnetted, 4 subnets
B 84.235.67.208 [20/0] via 84.235.77.85, 04:44:56
B 84.235.88.160 [20/0] via 84.235.77.85, 22:29:12
C 84.235.77.84 is directly connected, Serial0/0/0.104
B 84.235.83.68 [20/0] via 84.235.77.85, 5w1d
C 20.0.0.0/8 is directly connected, GigabitEthernet0/0
172.31.0.0/30 is subnetted, 1 subnets
B 172.31.2.152 [20/0] via 84.235.77.85, 2w2d
AL-AYUNI-OLAYA#
REMOTE :
AL-AYUNI-HAIRE#sh ip route
B 50.0.0.0/8 [20/0] via 172.31.2.153, 05:32:45 ---------------- Another Branch Office
B 84.235.67.208 [20/0] via 172.31.2.153, 04:39:33
B 84.235.88.160 [20/0] via 172.31.2.153, 22:23:49
B 84.235.77.84 [20/0] via 172.31.2.153, 1d19h
B 84.235.83.68 [20/0] via 172.31.2.153, 1d19h
B 20.0.0.0/8 [20/0] via 172.31.2.153, 1d19h ---------------------- Head Office
C 172.31.2.152 is directly connected, FastEthernet0.3429
C 192.168.1.0/24 is directly connected, Vlan1
AL-AYUNI-HAIRE#
3.
When I Try to Ping using Extended Ping as you specify...
AL-AYUNI-HAIRE#ping 20.0.0.10 source vlan 1
Sending 5, 100-byte ICMP Echos to 20.0.0.10, timeout is 2 seconds:
Packet sent with a source address of 192.168.1.2
Success rate is 0 percent (0/5)
4. Exactly its IP VPN using MPLS Clouds. I don't know about to check MTU & Frame Size issue...
Please explain this further
Thanks in advance
Abdul
If you have determined that the problem is that HQ does not have a route to the remote network then there is not much need to discuss MTU and frame size since the problem is obviously a routing issue not a fragmentation issue.
Without seeing details from the configs it is difficult to know exactly what the problem is, but it is evident that the remote is not advertising its network to HQ. I do not know whether there is not a network statement for the 192.168.1.0 network, or whether there is outbound route filtering on the remote or whether there is inbound route filtering at HQ. But for some reason the network from the remote is not getting into the routing table at HQ. And until it does get into the routing table at HQ the clients at the remote will not be able to access the server at HQ.
Rick
Rick
Rick
Thanks for your Support.
Im enclosing the Running Config @ HQ & Remote Location.
Running Config in HQ :-----------HQ---------
AL-AYUNI-OLAYA#sh run
Building configuration...
Current configuration : 4121 bytes
version 12.4
hostname AL-AYUNI-OLAYA
boot-start-marker
boot system flash c2800nm-advipservicesk9-mz.124-7a.bin
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$HmWK$KkbkSpGuJ4WcVpaEI1hA3.
no aaa new-model
resource policy
ip cef
ip domain name yourdomain.com
voice-card 0
no dspfarm
username abdul privilege 15 secret 5 $1$OPedl$smM/VjMP4A/cCfIFr/CGf/
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 20.0.0.1 255.0.0.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type ansi
interface Serial0/0/0.104 point-to-point
ip address 84.235.77.86 255.255.255.252
frame-relay interface-dlci 104
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
interface XTagATM0
no ip address
router bgp 64659
no synchronization
redistribute connected
neighbor 84.235.77.85 remote-as 65000
no auto-summary
control-plane
line con 0
login local
line aux 0
line vty 0
privilege level 15
password abdulvty
login
transport input telnet
line vty 1 4
privilege level 15
no login
scheduler allocate 20000 1000
end
AL-AYUNI-OLAYA#
Running Config in REMOTE :--------REMOTE------
AL-AYUNI-HAIRE#sh run
Current configuration : 3201 bytes
version 12.4
hostname AL-AYUNI-HAIRE
boot-start-marker
boot-end-marker
enable secret 5 $1$2bj.$5ejOc1TZt9XfYCR8v6mPlt.
no aaa new-model
resource policy
ip cef
username abdul privilege 15 password 0 asdf
no ip address
duplex auto
speed auto
ip nat outside
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
ip nat inside
interface Async1
no ip address
encapsulation slip
router bgp 64659
no synchronization
no auto-summary
control-plane
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
password abdul
login
webvpn context Default_context
ssl authenticate verify all
no inservice
end
AL-AYUNI-HAIRE#
Hope this will resolve my issues..
Abdul
Abdul
Thanks for posting the configs. When I first looked I thought that I had found the problem when I noted that the remote router is running BGP but is not advertising its local network. But when I looked more closely I believe that the real issue is something else. I note that the outbound interface FastEthernet0.3429 is configured with nat outside and that VLAN 1 is configured with nat inside. But I do not see any other nat configuration. If you will add the configuration to translate the VLAN 1 addresses using overload on the FastEthernet0.3429, then HQ will have a path to the remote subnet.
Rick
Rick
Rick
Sorry for belated reply.
I have added these two statments...
ip nat inside source list 1 interface FastEthernet0.3429 overload
access-list 1 permit 192.168.1.0 0.0.0.255
After this Client can access Server in HQ.
But Still HQ Router doesnt have the path to remote subnet.
How we can resolve this issue
Abdul
I am glad to know that my suggestion was effective in allowing the clients at the remote to access the server at HQ.
For solving the issue of HQ initiating traffic to the remote there are several alternatives that could work. Choosing which one is best would depend on knowing more about the design and setup of your network.
First lets be sure that we understand what is happening now: you are using dynamic translation with overload, which is generally called PAT (for Port Address Translation). In dynamic PAT when an end station initiates traffic to HQ the router generates an entry in the translation table which allows traffic from HQ to the end station to be correctly translated and delivered to the correct host. But if HQ initiates traffic there is not an entry in the translation table and therefore traffic from HQ can not be translated and delivered to the end station at the remote.
So one solution would be to configure some kind of static translation so that end stations would always have an entry in the translation table and HQ would be able to initiate traffic to them.
Another alternative would be to put a network statement under router bgp at the remote to advertise the LAN network through BGP to HQ. This would make all the end stations reachable without requiring any translation.
Perhaps looking at the other remote offices could show how they solve this issue and help choose the most appropriate alternative for this office.
Rick
Rick
Method 1.
HQ:
router bgp 64659
Remote:
no ip nat outside
interface Vlan1
no ip nat inside
router bgp 64659
I would like to thanks Rick and Slider.
I have tried Method 2. Working excellent.
Abdul.
