Cisco 1841 ip routing problem
mmunoz2000
Hello everyone!
I'm completely lost here, since I'm a newbie on this networking area.
I recently had a problem with a cisco router 1841 that lost all configuration after a power outage. Long story short, i've been able to restore most of it, but i'm still having issues with the ip routing. This is the scenario:
I have 2 internal VLANS (1010 and 3040) configured in a ZyXEL switch.
1010 has an ip 192.168.170.1
3040 has an ip 192.168.160.1
I have a Sonicwall on the other end that acts as a gateway with ip 192.168.168.1
On the router I have interface 0/0 as outside with ip 192.168.168.54
I also have 2 subinterfaces for the vlans with the ips mentioned before.
Everything works fine on the internal network, which is 192.168.168.x
I want traffic from VLANS to go outside to the internet
I want traffic to go inside to those VLANS from the internet
So far, from the router, i can ping all the gateways and the internet.
PC inside the 192.168.170.x network can reach the internet, but no one can reach that computer from the outside.
Please help me, i've been trying to figure this out a week from now, but no clue what am i missing!!!
See my current configuration:
interface FastEthernet0/0
ip address 192.168.168.54 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
no ip address
ip nat inside
ip nat enable
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1010
ip address 192.168.170.1 255.255.255.0
ip nat inside
ip nat enable
interface FastEthernet0/1.2
encapsulation dot1Q 3040
ip address 192.168.160.1 255.255.255.0
ip nat inside
ip nat enable
interface Serial0/0/0
no ip address
shutdown
interface Serial0/1/0
no ip address
shutdown
ip route 0.0.0.0 0.0.0.0 192.168.168.1
no ip http server
no ip http secure-server
ip nat source list 1 interface FastEthernet0/0 overload
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 192.168.170.0 0.0.0.255
access-list 1 permit 192.168.160.0 0.0.0.255
I would really appreciate any insight on this matter, since i need to have these up and running in a couple of days.
I hope you guys can help!
62 Replies 62
I was able to get it to work by doing a reload.
These are the results:
1) rtr can ping all the subnets
2) rtr cannot ping the internet
3) pc on the 192.168.168.x subnet can ping all the subinterfaces (192.168.170.1 and 192.168.160.1)
4) the same applies for a pc on the 192.168.170.x subnet (can ping its own gateway and other pcs on the network)
Here is the updated configuration:
ip nat outside
duplex auto
speed auto
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
no ip address
shutdown
no ip address
shutdown
no ip http server
access-list 1 deny 192.168.168.0 0.0.0.255
Any other ideas?
Thank you for the assistance though!!
Hello
remove the deny statement in nat acl
 When did you put that in -as it wasn’t in your OP ?
Kind Regards
Paul
The deny was there because of a suggestion from someone else on this post.
I still see the same results.
I have removed it and this is the updated configuration:
ip nat outside
duplex auto
speed auto
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
no ip address
shutdown
no ip address
shutdown
no ip http server
Any other suggestions?
Thanks!
Hello
i don’t see this nat statement anymore
“ip nat inside source list 1 interface FastEthernet0/0 overload”
if you don’t have in now please reapply it
Kind Regards
Paul
I have applied the change and now I see NAT translation happening.
Still cannot access from one subnet to the other.
here is the updated configuration:
ip nat outside
duplex auto
speed auto
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
no ip address
shutdown
no ip address
shutdown
no ip http server
Hello
Thought you said you had connectivity between vlans.
Okay just for clarifuxation  post the full configuration of that rtr please
Kind Regards
Paul
Sorry ir I wasn't clear, but the PCs can see each other on their own subnet.
The problem I'm trying to solve is that the vlans cannot see each other.
I cannot ping computers from 192.168.168.x to 192.168.170.x
They both have internet, but they cannot see each other.
Any other suggestions? I feel there is something in the NAT that I'm missing.
Hello
Nat really shouldn’t have anything to do with it
can you confirm-
1) do clients from either vlans have a default gateway of their respective Rtr L3 ip address ?
2) make sure the switchport on the switch connecting to the rtr is in a trunk
3) post the full configuration of the rtr -
Kind Regards
Paul
Clients have their own gateway pointing to the subinterfaces.
I will be able to validate the switchports tomorrow, since I do not have physical access to the switches right now.
how do i get the full configuration?
Hello
On the rtr
sh running-configuration
copy and post the output
Kind Regards
Paul
Here is the full configuration:
AP-CISCO-01#sh running-config
Building configuration...
Current configuration : 1172 bytes
version 12.4
hostname AP-CISCO-01
boot-start-marker
boot config flash:last-router-confg
boot-end-marker
no aaa new-model
resource policy
ip cef
ip nat outside
duplex auto
speed auto
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
no ip address
shutdown
no ip address
shutdown
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Let me know if you see anything that needs to be changed.
Thanks!!
Hello
you are missing a default route towards your Fw Which again was on your OP but now isn’t?
Please apply
conf t
ip routing
ip route 0.0.0.0 0.0.0.0 fa0/0 192.168.168.1
end
wr
(assuming that ipaddress above is the Fw lan ip address )
what’s the reasoning vlan numbering is quite sporadic- why do you have  1010 and  3040 which would indicate extended vlan as I am not familiar with that type of switch it could something to look into but not yet
lastly - when you get the chance confirm the switchport mode of the port connecting to the rtr
Kind Regards
Paul
I added the ip route to the Fw and now the rtr can ping the internet.
The VLANs were already configured this was and I really don't know if there is a reason for it.
I will be able to check the port connectivity tomorrow morning at around 7am EST. I was able to access the switch and verify that the ports are configured correctly, but I cannot guarantee that they are physically connected to those ports.
Is there any other way to validate that the trunk is working the way it should?
Thanks for all your help!
Another thing I noticed is that a PC on the 192.168.168.x network cannot ping the subinterface 192.168.170.1 or the 192.168.160.1
Not sure if this might help diagnose the problem.
Thanks!!
Hello
you shouldn’t have any pc on 192.168.168.0/24 that’s your Fw subnet not a lan subnet
Kind Regards
Paul
