Cisco 1900 Throughput 15Mbps?
Ricardo Duarte
Hi there,
About the 1921, I can see the following on the Cisco site:
- The Cisco 1900 Series enables deployment in high-speed WAN environments with concurrent services enabled up to 15 Mbps.
- Circuit-speed performance up to 25 Mbps with concurrent service
I don't need any VPN/IPSEC functionality. Just NAT and firewall.
From the datasheet, I'm lead to think I can only get a maximum of 15mbps from my WAN link, even if it can deliver more throughput.
But this value is quite low, compared to, say, an ASA5505 and even other non-enterprise devices.
Also, why does the router ships with 1Gbps when it can only reach 15Mbps?
Can someone give me some hint on how to read this value? Is this a soft limit? Can I never reach, say, 100mbit/s? What would I lose if I buy an ASA5505 instead of a 1921?
Jeff Van Houten
Level 5
Level 5
NAT and firewall take processing capacity, just like VPN. No low end routing device will run at link protocol negotiation speeds. If they did, why would there be a need for higher priced products?
You need to match your network requirements with the appropriate equipment given a budget constraint. All NGO professionals operate under this 3 way constraint model.
But ASA 5505 looks like a more powerful device for a cheaper , for nat and security.
What do I get with the router that i cant do with ASA?
The ASA is quite limited in what you can do with dynamic routing protocols. The router gives you a much wider choice of dynamic routing. The router has many features, such as Policy Based Routing, that the ASA does not have. The router gives you a much wider range of choices for Quality of Service than the ASA. The router suppports a range of interface types while the ASA gives you support for only Ethernet.
Rick
Rick
