Cisco 1921 Router Connection Issue
john.strode
This will sound errily similar to another post on this site.
I'm also new to Cisco router configuring. We are trying to configue a 1921 to communicate to our local ISP's gateway and a private network.
From the router we can ping the external dns server and we can also ping our internal network. However we can not ping from a pc on the internal network to the dns server on the external network.
I have attached our code..
Any help is greatly appreciated...
publib#show running-config
Building configuration...
Current configuration : 1059 bytes
! Last configuration change at 15:32:25 UTC Tue Nov 8 2011
version 15.0
service config
hostname publib
boot-start-marker
boot-end-marker
enable secret 5 $1$BVI7$cJKv7S3sPbk1N5e8Y5WYJ.
enable password
no aaa new-model
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO1921/K9 sn FCZ1519C10N
redundancy
interface GigabitEthernet0/0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip address 64.130.179.126 255.255.192.0
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 64.130.128.1
control-plane
line con 0
line aux 0
line vty 0 4
password
login
scheduler allocate 20000 1000
end
you haven't configure NAT rule on you router, you need something like
   access-list 101 permit ip 192.168.1.0 0.0.0.255 any
   ip nat source list 101 interface gi0/1 overload
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
Thanks for the info.. We'll try that and see if it solves the issue.
