Cisco 2901 basic config for internet access
brcruz001
Community Member
Hi there,
This is my first time playing with a Router. I have a Cisco 2901, and despite the many different topics and how-to's available here and in other places, I still can't get internet access to my computer behind the router. I have a modem (provided by my ISP) connected to my router's GE0/0 port, and a computer connected on interface GE 0/1. What have I accomplished so far:
- Router is getting an DHCP IP from ISP;
- Router can ping computer, and computer can ping router. From my computer I can even ping Router's GE0/0/;
- Router can ping internet resources, computer behind it cannot;
Here's my show-run-config:
C2901#show running-config
Building configuration...
Current configuration : 1531 bytes
! Last configuration change at 21:37:52 UTC Sat Jan 16 2016
version 15.1
hostname C2901
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXXXXXXXXXXXXXXX.
enable password XXXXXXX
no aaa new-model
no ipv6 cef
ip source-route
no ip routing
no ip cef
ip name-server 201.17.0.79
voice-card 0
license udi pid CISCO2901/K9 sn FTX172885WN
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
interface Loopback0
 ip address 192.168.254.1 255.255.255.0
 ip virtual-reassembly in
interface GigabitEthernet0/0
 description INTERNET
 ip address dhcp
 ip nat outside
 no ip route-cache
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description LAN
 ip nat inside
 no ip route-cache
 duplex auto
 speed auto
 no mop enabled
interface Virtual-Template1
 ip unnumbered Loopback0
 ip nat outside
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
gatekeeper
 shutdown
banner exec ^CEntering EXEC mode on R2901...^C
line con 0
line aux 0
line vty 0 4
 password XXXXXXXX
 login
 transport input all
scheduler allocate 20000 1000
ntp server 200.186.125.195
end
I know there area a few things missing (ACL's), but as my first step, I just want to connect to the internet.
Can anyone help?
brcruz001
Community Member
I made a few changes, but still no connectivity from my computer to the internet. Here's my updated build:
Current configuration : 1777 bytes
! Last configuration change at 12:30:21 UTC Sun Jan 17 2016
version 15.1
hostname C2901
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXXXXXXXXXXXXXXXX
enable password XXXXXXXX
no aaa new-model
no ipv6 cef
ip source-route
no ip routing
no ip cef
voice-card 0
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
interface Loopback0
 ip address dhcp
 ip nat outside
 no ip route-cache
 duplex auto
 speed auto
 description LAN
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat inside
 no ip route-cache
 duplex auto
 speed auto
 no cdp enable
 no mop enabled
no ip http server
ip nat pool NATPOOL 192.168.0.11 192.168.0.11 prefix-length 24
ip nat inside source list 1 pool NATPOOL overload
ip route 0.0.0.0 0.0.0.0 192.168.0.1
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
gatekeeper
 shutdown
line con 0
line aux 0
line vty 0 4
 password XXXXXXXX
 login
 transport input all
end
Hi have you tried
ip nat inside source list 1 interface gi0/0 overload instead you don't need the NAT  pool then
and in case there is a restriction from the Internet modem
Hi Richard,
Thanks for your reply. Another post caught my attention to a detail i didn't posted. Running "show ip route" I couldn't see my routing table. After checking another post I realized that ip routing was not enabled on the router.
After running the command "ip routing"on config, routing was enabled and the router's routing table was populated, enabling internet access to the computer behind it.
Thanks anyway for your help.
