Cisco 7600 sup-bootdisk
patcbr600
Hi all,
On a cisco 7600 rsp720 we have a RP compactflash and also a SP compactflash, how do we access RP flash and SP flash, also when we do a show sup-bootdisk what compact flash are we seeing.
Many Thanks
Jerry Ye
Hi Patricio,
sup-bootdisk: is the flash memory on the SP. The RP flash memory is bootflash:.
sup-bootdisk: is also called sup-bootflash: depend on the version of IOS you are using. You can use show file system to check out the flash memory in your SUP card.
HTH,
jerry
