Cisco 877 dial in backup !!!
craig.bufton
hello all, I am working on a solution where by, should an ADSL link fail i would like to be able to dial in to a cisco 877 by using the console port connected to a anologe modem. I have already created a virtual AUX port and been able to connect by dialing the modom but i am getting suck on authing the dialin session and gettin an ip form the router which has a DHCP pool already set up help please..
many thanks
swittner
So you want the 877 to dial back to a central site (or ISP) if the ADSL link goes down?
Where is the authentication failing? I assume this is a PPP connection - right?
Please post some of your config.
no what i want to do is, be able to connect in to the 877 via the console port through a dial in modem which will be attached to the console port using the virtual aux port which i have configurd in the 877. what i am looking for is the correct settind=gs to out on the 877 which will allow incoming telnet or ssh to allow me to make config chages using the anologe modem to connect to the 877
I have done this in the past by putting a USR Sportster 33.6 modem on the console. Put the modem in Auto Answer mode.
Auto Answer
ats0=1&w
