Cisco 881 don't have eigrp
brownsfan31
I have a cisco 871 that is running eigrp. I am replacing this with a cisco 881 ISR with C880DATA-UNIVERSALK9-M), Version 15.2(4) and it requires advanced IP services IOS. I can not find advanced ip services online. Is there a way around this? Only routing protocol is OSPv3 and RIP..
Thanks in advance
EIGRP is opening at license IPBaseK9. You need activate SL-880-AIS
http://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/white_paper_c11_499859.html
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/software-activation-on-integrated-services-routers-isr/white_paper_c11_556985.html
5 Replies 5
Leo Laohoo
Post the output to the command "sh license".
Here is the Sh license results.
ctm881#sh license
Index 1 Feature: advipservices
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Not in Use, EULA not accepted
        License Count: Non-Counted
        License Priority: None
Index 2 Feature: advsecurity
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
Index 3 Feature: ios-ips-update
Index 4 Feature: WAAS_Express
Index 5 Feature: SSL_VPN
        License Count: 0/0  (In-use/Violation)
Here also is the sh ver:
ctm881#sh ver
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.2(4)M5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 13-Sep-13 21:42 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
ctm881 uptime is 57 minutes
System image file is "flash:c880data-universalk9-mz.152-4.M5.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 881 (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID FTX1813850W
5 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
125496K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO881-K9           FTX1813850W
License Information for 'c880-data'
    License Level: advsecurity   Type: Permanent
    Next reboot license Level: advsecurity
brownsfan31
rus-admin,
Thanks for your help on this. I was able to go in and accept the EULA then set the 881 to boot to advancedipsvc and then did the reload. this activated the licence for temp 8weeks 4 days. This gives me time to get the license and activate. I appreciate it.
