Cisco ACE and VRF
vinovinom
Hi All
I am trying to design a network with already existing Cisco ACE modules in 6509 which needs to load balance between the severs which are behind the firewall. I just need to know how to design this scenario as I am new to design as I come from implementation background. Please advise as possible...
I got another architect describing that we need to use a Source NAT and vrf so that we can make ACEs sit logically behind the firewall with VLANs. I just need to know how about doing that ? I am new to load balancing as well.
If someone can point me to the right direction to do this would be very helpful.
Vinoth D
Jon Marshall
vinovinom wrote:
Hi All
Vinoth D
Vinoth
If you are using VRF's then the logical choice on the ACE modules would be to use contexts and map those to a vrf. But that is only a general comment. If you are new to load-balancing/ACE modules then it could be a steep learning curve.
Regardless of the above this is really the wrong forum for this request. You would get much better help if you posted this into the "Data Center -> Application Networking" forum which is specifically about load-balancing etc..
Jon
Jon Marshall
vinovinom wrote:
Hi All
Vinoth D
Vinoth
Jon
Many thanks John ... I would post over there ...
Vinoth
