Cisco ASA Policy-Based Routing for branch office to internet
curcloin
I have a new branch office with an internet connection and a P2P/MOE back to our main office.  I want the internet traffic at the branch to go out our internet connection at the branch but also use the main office internet as a backup.  Is something like this possible with an ASA 5508x?
Francesco Molino
Default route will be your local isp and in case this link is down default route must the second line through your main office, am i getting it right?
If so, you don't need pbr, using tracking will be simpler.
Here a guidance document on how to implement that:
https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/118962-configure-asa-00.html
If you need help to build your specific config, let me know
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
As already mentioned by Francesco, this can be handled by routing. But the connection to the main-office needs to be able to handle the traffic for the internet.  That can be tricky if it is a kind of VPN-connection.
