CISCO ASR1002-x: Critical software exception
thestudent101
What does critical software exception means? Thank you
Router01 uptime is 6 days, 1 hour, 15 minutes
Uptime for this control processor is 6 days, 1 hour, 18 minutes
System returned to ROM by Critical software exception, check bootflash:crashinfo_RP_00_00_20190705-153903-PHILIPP
System restarted at 15:45:55 PHILIPP Fri Jul 5 2019
System image file is "bootflash:/asr1002x-universalk9.16.07.01.SPA.bin"
Last reload reason: Critical software exception, check bootflash:crashinfo_RP_00_00_20190705-153903-PHILIPP
9 Replies 9
Leo Laohoo
Update the firmware.
Alternatively, raise a TAC Case and give them the crashinfo file for analysis.
premspandey1995
critical software exception means software crash. You may find out the crash file in your bootflash, you just need to open a TAC case with Cisco & provide the crash file in order to find out the reason for the crash.
For your understanding, I am enclosing the link
https://www.cisco.com/c/en/us/support/docs/routers/7500-series-routers/26145-crashes-swforced-troubleshoot.html
Thank you & have a great time!!
wag-web
I'm facing the same issue right now.
Have you found a solution?
Each crash is unique.
Please provide more information.  Start with "sh version".
Hello Leo. Thanks for your response...
I found in my log the following lines:
*Dec 11 17:13:39.909: %IOSXE-5-PLATFORM: R0/0: cpp_cp: QFP:0.0 Thread:105 TS:00000049356367826532 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt policer drops packets, cause: for-us-data (0xb) from Port-channel1.10
CMD: 'show plat hard qfp act infra exmem stat diram' 15:13:40 BRV Wed Dec 11 2024
CMD: 'show plat hard qfp act infra exmem stat diram' 15:13:46 BRV Wed Dec 11 2024
*Dec 11 17:13:48.439: %AAA-3-ACCT_LOW_MEM_UID_FAIL: AAA unable to create UID for incoming calls due to insufficient processor memory
*Dec 11 17:13:50.629: %AAA-3-ACCT_LOW_PROC_MEM_TRASH: AAA unable to handle accounting requests due to insufficient processor memory and could be trashing the queued accounting records
CMD: 'show plat hard qfp act infra exmem stat diram' 15:13:51 BRV Wed Dec 11 2024
*Dec 11 17:13:52.309: %SYS-2-MALLOCFAIL: Memory allocation of 2756 bytes failed from 0x80005620B4ED8A99, alignment 8
Pool: Processor Free: 609440 Cause: Memory fragmentation
Alternate Pool: None Free: 0 Cause: No Alternate pool
-Process= "Pool Manager", ipl= 0, pid= 10
Is there any kind of solution or at least some workaround for that?
Post the complete output to the following commands:
sh version
sh platform resources
sh version
Cisco IOS XE Software, Version 16.09.07
Cisco IOS Software [Fuji], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Wed 10-Feb-21 09:19 by mcpre
platform resources
**State Acronym: H - Healthy, W - Warning, C - Critical
Resource Usage Max Warning Critical State
RP0 (ok, active) H
Control Processor 9.90% 100% 80% 90% H
DRAM 6752MB(42%) 15919MB 88% 93% H
ESP0(ok, active) H
QFP H
TCAM 66cells(0%) 524288cells 65% 85% H
DRAM 443568KB(42%) 1048576KB 80% 90% H
IRAM 12245KB(9%) 131072KB 80% 90% H
CPU Utilization 10.00% 100% 90% 95% H
Memory utilization for both the control-plane and the QFP are abnormally high (both at 42%).  It should not be >25%.
wag-web
Ok.. Got it!
I'll check that...
This router is running BGP and some services.
I'll try to "clean" at maximum. Thanks for your help!
