Cisco ASR1K GE 'loopback mac' command
johnlloyd_13
Level 11
Level 11
hi,
i'm trying to troubleshooting an ISP circuit in ASR1K and trying to push back the issue to the ISP.
can someone advise if it's possible to perform loopback test in a GE port? i've done this in serial E1 link where you can configure a loopback towards the provider.
what is the function of the 'loopback mac' command under GE interface. is it the same as doing a hard loop towards the provider?
ASR1K(config-if)#loopback ?
mac Loopback towards system at the MAC controller level
ASR1K(config-if)#loopback mac ?
<cr> <cr>
Giuseppe Larosa
Hello @johnlloyd_13 ,
loopback MAC should loop towards the router interface controller not in the direction of the provider
see the attached document the command provides a local loopback towards the router and allows to verify your side.
The document provides also a suggestion to use two different VRFs to test SFPs and cables on a single router box
Hope to help
Giuseppe
