Cisco box
rolexreyes
Community Member
I need help in our 2 requirements.  I need a specific cisco router model that can accomodate this modules.
Box 1  -  1 unit HWIC-4T
              2 unit NM-16ESW  or 1 32ports NM-ESW
              1 NME-AIR-WLC25-K9
Box 2 - 2 unit HWIC-4T
             1 unit NM-16ESW
Thanks and Best regards,
Rolex
5 Replies 5
InayathUlla Sharieff
Rolex,
2800 series should help you.
http://www.cisco.com/c/en/us/products/routers/2800-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
Inayth
Hi Inayth,
thank you for the response.  Actually I'm looking on cisco 3945 but when i tried using the cisco configurator I can't find the module. Can you help me on this? Can you give me an exact part number which can accomodate this 2 requirements?
Thank you...
Rolex,
http://www.cisco.com/c/en/us/products/routers/3900-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
I dont see the above parts supported on thie 3900 series router.(HWIC-4T is supported but not the NM).
2-
I can see all the above modules are supported on 3800 series routers hence you can think of going with this:-
Supported modules:-  1 unit HWIC-4T    2 unit NM-16ESW  or 1 32ports NM-ESW &   1 NME-AIR-WLC25-K9
http://www.cisco.com/c/en/us/products/routers/3800-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
Inayath
*********Please do not forget to rate all usefull posts**********
Hi Inayth,
3800 series is end-of-sale since nov 2011. That is why im looking on 3900 series. I can change the nm to service module if needed. Any recommendation? Thanks.
Rolex,
Yes if you can change the nm module then 3900 series is good go.
