11-06-2025 03:19 AM
dualstatic Hello,
We have a dual ISP setup on a Cisco 927 using FTTP (primary) and SoGEA (secondary), both via PPPoE and controlled by IP SLA/Route Map.
When FTTP is active, the SoGEA connection becomes unreachable, preventing proactive monitoring of the backup link. Since the goal is to maintain visibility on both connections, how can we configure the router to ensure the secondary SoGEA WAN interface remains pingable while the primary FTTP route is active?
track 1 ip sla 1 reachability
delay down 30 up 30
interface ATM0
no ip address
load-interval 30
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Ethernet0
no ip address
interface Ethernet0.101
encapsulation dot1Q 101
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
description FTTP WAN
no ip address
duplex auto
speed auto
pppoe-client dial-pool-number 2
interface Vlan1
description LAN
ip address 10.8.20.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface Dialer1
description SoGEA Backup
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
no cdp enable
ppp authentication chap callin
interface Dialer2
description FTTP Primary
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 2
dialer persistent
dialer-group 2
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map FTTP-PRIMARY interface Dialer2 overload
ip nat inside source route-map SOGEA-BACKUP interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer2 track 1
ip route 1.1.1.1 255.255.255.255 Dialer2 permanent
ip sla 1
icmp-echo 1.1.1.1 source-interface Dialer2
threshold 200
timeout 400
frequency 20
ip sla schedule 1 life forever start-time now
route-map FTTP-PRIMARY permit 10
match ip address 100
match interface Dialer2
route-map SOGEA-BACKUP permit 10
match interface Dialer1
tftp-server flash:/firmware/vadsl_module_img.bin
access-list 100 permit ip 10.8.20.0 0.0.0.255 any
control-plane
scheduler allocate 20000 1000
event manager applet PRIMARY_DOWN
event track 1 state down
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "no ip route 0.0.0.0 0.0.0.0 Dialer2"
action 4.0 cli command "ip route 0.0.0.0 0.0.0.0 Dialer1 200"
action 5.0 cli command "end"
action 6.0 cli command "clear ip nat translation *"
event manager applet PRIMARY_UP
event track 1 state up
action 3.0 cli command "no ip route 0.0.0.0 0.0.0.0 Dialer1"
action 4.0 cli command "ip route 0.0.0.0 0.0.0.0 Dialer2 track 1"
end
_________________
ping from router
#ping 8.8.8.8 source dialer 1
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 5.2.98.235
Success rate is 0 percent (0/5)
11-06-2025 03:39 AM
interface Dialer1
you can use a specific destination within the SoGEA network as destination of your ping
like one of it's DNS servers, or the other end of the dialer1 connection?
and adding a route specifying the dialer1 interface to this specific address?
11-06-2025 04:43 AM - edited 11-06-2025 06:09 AM
I have a static route in place for Dailer1, which runs using EEM script
Adding a route to the next hop IP address will enable ICMP reachability from external sources.
11-06-2025 07:22 AM
>>> which runs using EEM script <<<
this EEM script runs when the primary links is down to modify the default route?
-> that is not what I meant!
if you want to check the availability of the SoGEA link using a ping from a host in your network
you need a route to a host on the SoGEA network using the SoGEA link when the FTTP link is UP (not using the default route)
