Cisco Model 881 - Unable to NAT to web server
isaaczhun
I hope there any someone here can help me out.
Apparently the problem seems simple enough however I couldn't get it working. My router is being configured to access a web server in the network which is on port 80. However, port 80 is being used by my router's setup page. Therefore whenever I key in my public IP address, it will just immediately direct me to the router's page.
I have also tried opening up other ports like 5050 and set my web server to port 5050. Internally within the LAN itself everyone can access the web server with port 5050. However, going from public IP address with port 5050 doesn't work. Am I missing anything here?
All the firewalls are configured.
Thanks in advanced.
45 Replies 45
Hello Toshi,
Could you please help me solved my issue as well. My issue is
I am not able to connect to the public domain name of web server from
my internal office network.
But I have no problem connecting to this domain name from my home internet.
Please advise what could have gone wrong. Is there any configuration
settings required to allow this to work on my internal network?
I have pasted the Cisco router running configuration in case you need to reference as below. Thanks
Best Regards,
May Thu
Current configuration : 2445 bytes
! Last configuration change at 07:59:44 UTC Fri Jun 7 2013
version 15.0
no service pad
no service password-recovery
hostname xxxxxx
boot-start-marker
boot-end-marker
enable password enable
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 192.168.12.1
ip dhcp pool lan
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
   dns-server 210.23.4.6 210.23.1.3
   lease infinite
ip dhcp pool VOICE-POOL
   import all
   network 192.168.11.0 255.255.255.0
   default-router 192.168.11.1
ip dhcp pool GUEST-POOL
   network 192.168.12.0 255.255.255.0
   default-router 192.168.12.1
ip cef
no ipv6 cef
license udi pid CISCO881-SEC-K9 snxxxxxxxx
interface FastEthernet0
description AUTONONOMOUS AIR
switchport trunk allowed vlan 1,2,1002-1005
switchport mode trunk
interface FastEthernet1
description AUTONOMOUS
switchport access vlan 2
interface FastEthernet2
interface FastEthernet3
description GUEST VLAN
switchport access vlan 3
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex full
speed 100
interface Vlan1
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface Vlan2
description VOICE VLAN
ip address 192.168.11.1 255.255.255.0
ip nat inside
interface Vlan3
ip address 192.168.12.1 255.255.255.0
  ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
no ip nat service sip udp port 5060
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.10.248 5500 interface FastEthernet4 5500
ip nat inside source static tcp 192.168.10.252 80 interface FastEthernet4 80
ip route 0.0.0.0 0.0.0.0 dhcp
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 192.168.11.0 0.0.0.255
access-list 1 permit 192.168.12.0 0.0.0.255
snmp-server community nwtngn RO
snmp-server ifindex persist
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password enable
login
scheduler max-task-time 5000
end
