Cisco Router DHCP
emilyforcisco1
Is there a way to specify a certain IP range for a DHCP pool on a Cisco 2901?
I am familiar with the typical set up of a range that goes from 172.16.x.1 - .254
But I need to set an existing range to be something like 172.16.x.25 - 199.
I can excluded IPs, but that isn't what I really want to do unless its the only way to make sure the router doesn't assign IPs in the range that are already in use by static devices
willwetherman
You need to exlcude parts of the range that you do not want to allocate by using the 'ip dhcp exclude-address' command.
Taking your example, to configure a DHCP pool to only allocate IPs within the range 172.16.1.25 to 172.16.1.199 you would configure the following:
ip dhcp excluded-address 172.16.1.1 172.16.1.24
ip dhcp excluded-address 172.16.1.200 172.16.1.254
ip dhcp pool Test
   network 172.16.1.0 255.255.255.0
   default-router 172.16.1.1
Hope this helps
