Cisco Switch routing to Voice VLAN to different router. Help!
efowler
Hello all, currently I have a Cisco Switch that is routing all VLAN 10 (Voice) traffice to a different router.  We are wanting to get ride of that router (ASA 5505) and want all the VLAN 10 traffic to go out the same location as the VLAN1 (data) router.  Our phones that use this VLAN are on a different subnet (192.168.16.x) and use the gateway 192.168.16.1.  Here is the show run from the cisco switch.
interface Port-channel1
switchport trunk allowed vlan 1,10
switchport mode trunk
flowcontrol receive on
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface GigabitEthernet1/0/1
description Trunk to Copy Room
channel-group 1 mode active
spanning-tree portfast
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
description ESX Host iSCSI Connectivity
switchport access vlan 101
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
description Uplink to 1921 Phone Router
switchport voice vlan 10
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
description SAN Management Port
interface GigabitEthernet1/0/45
description SAN iSCSI
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
description wlspoe1 - port g1 - 192.168.1.20
interface GigabitEthernet2/0/18
description wlspoe2 - port g1 - 192.168.1.21
interface GigabitEthernet2/0/19
description Barracuda F380 Port 5
switchport access vlan 200
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface GigabitEthernet2/0/29
interface GigabitEthernet2/0/30
interface GigabitEthernet2/0/31
interface GigabitEthernet2/0/32
interface GigabitEthernet2/0/33
interface GigabitEthernet2/0/34
interface GigabitEthernet2/0/35
interface GigabitEthernet2/0/36
interface GigabitEthernet2/0/37
interface GigabitEthernet2/0/38
interface GigabitEthernet2/0/39
interface GigabitEthernet2/0/40
interface GigabitEthernet2/0/41
interface GigabitEthernet2/0/42
interface GigabitEthernet2/0/43
interface GigabitEthernet2/0/44
interface GigabitEthernet2/0/45
interface GigabitEthernet2/0/46
interface GigabitEthernet2/0/47
interface GigabitEthernet2/0/48
interface GigabitEthernet2/1/1
interface GigabitEthernet2/1/2
interface GigabitEthernet2/1/3
interface GigabitEthernet2/1/4
interface TenGigabitEthernet2/1/1
interface TenGigabitEthernet2/1/2
interface TenGigabitEthernet2/1/3
interface TenGigabitEthernet2/1/4
interface Vlan1
description Data
ip address 192.168.1.1 255.255.240.0
interface Vlan10
description Voice
ip address 192.168.16.254 255.255.255.0
ip helper-address 192.168.0.6
interface Vlan101
description iSCSI VLAN
no ip address
interface Vlan200
description Uplink to Barracuda F380
ip address 10.200.200.2 255.255.255.252
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip tftp source-interface GigabitEthernet2/0/43
ip tftp blocksize 8192
ip route 0.0.0.0 0.0.0.0 10.200.200.1
My guess is to remove the switchport access and voice VLAN on port 1/0/24?  Will that stop the routing of the VLAN 10 traffic to that port?  And then by default just route VLAN 10 to the F380 like the data traffic?
I have already created a static route on my router (F380) for the 16 subnet.
this make phone have GW is SVI VLAN 10 in SW and then the traffic will forward to Barracuda
7 Replies 7
can you draw the topology
I added a picture that may help!
if you want to delete the connect for VLAN10 in ASA
Added more information!
I changed the
default gateway
and had to activate the network in barracuda.  All works now thanks again!
 Do you have any IP address on the network 192.168.16.0 on the  ASA side?  If you do and you want to move the network to Brocade you need to remove. Direct connected network will have preference.
