Clear Counters
erikbragaccna
Community Member
Does anyone know what is the command that will ONLY clear my E1 counters? Its a 3800 series router.
I think the command is "clear counters serial" then I enter 4/0/1 but it says command is unrecognized.
E1 4/0/1 is down.
  Applique type is Channelized E1 - balanced
  Description: Cisco TAC default config for BR
  Receiver has loss of signal.
  alarm-trigger is not set
  Version info Firmware: 20090113, FPGA: 20, spm_count = 0
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
  Data in current interval (318 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 318 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
Vishesh Verma
Level 6
Level 6
Use "clear controller" EXEC command to reset the T1 or E1 Controller.
Clear controller {t1 | e1} Slot/Port
Clear controller {t1 | e1} number
t1 = specifies the T1 Controller
e1 = specified the e1 controller
Slot/Port = Backplane slot number or port number on the interface.
number = Network Interface Module Number, in the range of 0 through 2.
-Vishesh
Hello
Clear counters- but this will clear all interface counters - not sure of a specific command have you checked to see what options the iOS is offering
via ..clear counters ?
Res
Paul
Kind Regards
Paul
Vishesh Verma
Level 6
Level 6
-Vishesh
This will reset the counter and not the configurations correct?
