CLNS error: neighbor forgot us
atif-siddiqui
I have seen this strange error, ISIS flapped and was back up, but the best forwarding path was unable to forward packets it seems, router not reachable via telnet/ssh , can ping the interface, but traffic was being black holed. BGP , LDP session went down while ISIS was up.
someone have seen this ' CLNS error' neighbor forgot us.
FIX: shut / no shut the interface.
Mar 6 02:05:39.261 EST: %CLNS-5-ADJCHANGE: ISIS (prj): Adjacency to router5W (GigabitEthernet5/1) Down, neighbor forgot us
Mar 6 02:05:39.281 EST: %CLNS-5-ADJCHANGE: ISIS (prj): Adjacency to router5W (GigabitEthernet5/1) Up, new adjacency
Mar 6 02:07:00.989 EST: %LDP-5-NBRCHG: LDP Neighbor x.x.x.129:0 (3) is DOWN (Discovery Hello Hold Timer expired)
Mar 6 02:07:45.134 EST: %BGP-5-ADJCHANGE: neighbor x.x.x.31 Down BGP Notification sent
Mar 6 02:07:45.134 EST: %BGP-3-NOTIFICATION: sent to neighbor x.x.x.31 4/0 (hold time expired) 0 bytes
Mar 6 02:08:06.882 EST: %LDP-5-NBRCHG: LDP Neighbor x.x.x.181:0 (1) is DOWN (Session KeepAlive Timer expired)
Mar 6 02:09:29.262 EST: %CLNS-5-ADJCHANGE: ISIS (prj): Adjacency to router5W (GigabitEthernet5/1) Down, neighbor forgot us
Mar 6 02:09:29.282 EST: %CLNS-5-ADJCHANGE: ISIS (prj): Adjacency to router5W (GigabitEthernet5/1) Up, new adjacency
Cisco 7606:
Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRB2, RELEASE SOFTWARE (fc1)
bwilmoth
Level 5
Level 5
"Neighbor forgot us" could mean, that the dead timer on the other side fired and the other side sends a new init
ana.peric
I had the similar problem with 12.2(33)SRB3 IOS.
In my case isis routing was up after shut / no shut of physical interface, and what is even more strange, isis process on router that was 5 to 8 hops away from 7600 was up too after interface reset.
atif-siddiqui, did you find an answer to this issue???
Best Regards,
Ana
