Conditional Response Mode in EIGRP -- Need clarification
fernster
I have tried searching the CCO for a good explanation on this topic. While have the just of it, I would like to see if anyone can give a good in depth explanation or point me to a resource within the Cisco web site to get information on it. Thank you.
ruwhite
Level 7
Level 7
I don't know of any good place to point you to, but I can explain it here. Assume you have three routers on a broadcast segment, A, B, and C.
-- A sends out some reliable packet (it could be an update, query, etc--anything reliable).
-- B acknowledges the packet, but C doesn't.
-- A's retransmission timer counts, and then expires (this timer is actually bound up with the multicast flow timer and the RTO, but I won't confuse the issue with all the relationships there).
-- A will then send out a hello with the CR (conditional receive) bit set, and a list of neighbors that should not pay attention to future multicast packets. C would be on this list, since we are unicasting to C.
-- A will now begin unicasting missed packets to C. If new updates are queued for transmission on the link, A will multicast these to the other routers on the link (B, in this case). A will also unicast these packets to C, waiting for C to ack each one.
-- When A has received an ack for all outstanding routing information queued for transmission from C, it will send out a new hello with the CR bit set, and an empty list of neighbors that should ignore multicast from A. This clears the CR mode.
Russ.W
Hi Russ,
So,
Is it correct to say that B (the normal router still receiving multicast RTP packets) is in CR mode or C (the multicast non-responsive router now receiving unicast RTP packets) is in CR mode?
I get confused when people refer to
" a router in CR mode "
Could you help with this?
Kind regards,
Ken
Well,
fernster did not ACK the forum message of Russ ... maybe he understood and they went into CR mode (email??)? ;-)
Cheers
Martin
