Configure ripv2 ospf and BGP
gauntlet16
hi, my name is martin, im from argentina, im doing a job for my
university, conecting 2 networks, one works with RIPv2 ant the other
with OSPF, th 2 are linked by a BGP link..
im using boson netsim to simulate this... i got the two netwoks
configred correctly, but i cant get BGP up...
here is the net diagram
http://img517.imageshack.us/img517/1193/topologiame5.jpg
and the router 4 config
[CODE]
Version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname Router4
ip subnet-zero
interface Serial0
ip address 10.114.2.1 255.255.255.252
no ip directed-broadcast
interface Serial1
ip address 10.114.1.2 255.255.255.252
clock rate 50000
interface Serial2
ip address 10.115.9.1 255.255.255.252
router rip
version 2
network 10.114.0.0
router bgp 1
network 10.114.1.0 mask 255.255.255.252
network 10.114.2.0 mask 255.255.255.252
network 10.114.3.0 mask 255.255.255.252
network 10.114.4.0 mask 255.255.255.252
neighbor 10.115.9.2 remote-as 2
interface FastEthernet0/0
no ip address
shutdown
interface FastEthernet0/1
no ip address
shutdown
ip classless
no ip http server
line con 0
transport input none
line aux 0
line vty 0 4
login
password martin
no scheduler allocate
end
[/CODE]
router 5 config
[CODE]
Version 12.1
hostname Router5
ip subnet-zero
interface Serial0
ip address 10.111.8.1 255.255.255.252
interface Serial1
ip address 10.111.7.2 255.255.255.252
clock rate 50000
interface Serial2
ip address 10.115.9.2 255.255.255.252
clock rate 50000
no ip address
shutdown
no ip address
shutdown
router ospf 1
network 10.111.8.0 0.0.0.255 area 0
network 10.111.7.0 0.0.0.255 area 0
router bgp 2
network 10.111.8.0 mask 255.255.255.252
network 10.111.7.0 mask 255.255.255.252
network 10.111.6.0 mask 255.255.255.252
network 10.111.5.0 mask 255.255.255.252
neighbor 10.115.9.1 remote-as 1
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
login
password xxx
end
[/CODE]
can someone point my how to solve this??
thanx..
Richard Burts
Martin
It is difficult to tell from this whether you have run into some issue with the simulator or whether it is something else.
So first, can you be a bit more specific about what you mean when you say cant get BGP up? When you do show ip bgp what does it say about the neighbor? While I wonder about the usefulness of having 4 network statements for networks with /30 masks that should not impact getting BGP up. In the configuration as posted I would expect BGP to form the neighbor relationship.
Also can you tell whether the serial link that connects them is up? If you perform show cdp neighbor, does it show the routers as neighbors at layer 2?
Rick
Rick
hi, if i run sh cdp neighbor i can see the 3 neighbors, and all the links are UP..
the problem i ges is the config of the bgp..
sh ip bgp shows only 2 networks.
on router 4 the 10.114.1.0 and the 10.114.2.0
and on router 5 10.111.8.0 and 10.111.7.0
any idea?
Martin
Can you post the output of show cdp neighbor detail from router 4 (and/or router 5)? Also the output of show ip bgp neighbor would be helpful.
The BGP configuration that you post is fairly simple and straightforward. Assuming correct connectivity between router 4 and router 5 I do not see anything that would keep it from forming the neighbor relationship.
I believe that there are 2 routes listed because those are the locally connected routes. I assume that the other networks that are represented by network statements are remote networks that you expect to learn via RIP or OSPF? I would interpret from what you have said that either they are not being leaerned, or they are being learned but do not have /30 masks. Posting the output of show ip route would clarify this.
Rick
Rick
yes those routes are directly conected to the routers. the other networks configured in bgp 1 and bgp 2 are the nets i whant to pass to the the other AS.
have you seen the diagram image http://img517.imageshack.us/img517/1193/topologiame5.jpg
al rip area routers now each other, i want them to know also the routers in ospf area, and to do this i use bgp
... here are the info i got from the routes.
http://img514.imageshack.us/img514/6733/router4oo8.png <-- router 4
http://img225.imageshack.us/img225/1362/router5oo5.png <-- router 5
