Configured IPv6 EIGRP routing but not able to ping PCs to each other
iamRob
I am not able to ping between each PCs after configuring EIGRP routing. IPv6 addresses are used and .pkt file is attached in attachment below.
Thanks in advance.
Harold Ritter
Hi @iamRob ,
The eigrpv6 configuration is fine. You configured the PCs as static, but omitted to configure the default gateway. Configure the default GW on the 3 PCs and you will be able to ping all of them.
Harold Ritter
Hi @iamRob ,
Oh wow.. All the way I was assigning default gateway in "link-local" address. Thank you so much for the help.
