Configuring a serial port in IOS 15.1(3)T
manuel.dennis
I just installed a HWIC-2T in a Cis
co 3845 running IOS 15.1(3)
T  New build.
The IOS self installed the port configuration including the command line "clock rate 2000000."  I can edit everything but that entry using the CLI.  When I enter the "no clock rate"  it will not take in the running conf.  ???????
Peter Paluch
Hello Manuel,
That behavior is normal for recent IOS versions. The clock rate command will be displayed either if there is no cable connected to the interface, or if the cable type is DCE in which case your router must provide the clocking function, hence the clock rate command. You can modify its value but you cannot remove it from the interface using the no form. The command will disappear automatically when you connect a DTE cable to the interface.
Best regards,
Peter
Peter Paluch
Hello Manuel,
Best regards,
Peter
Peter,
I thought that might be the case, but could find no documentation that said it was.  Hardware documentation is very much lacking and the link in what came with the module goes nowhere.  And searching the Cisco site for technical hardware information was a wasted effort.  All I could find was the command reference that told me the "no" command should remove the command.
Thank you.
Manny
