Configuring BGP exclude one subnetwork (network command) - ASR1002-X
martin.germano
Level 2
Level 2
  Hi all, i'm brand new on BGP, so i try to connect to another AS:
router bgp 100
 bgp log-neighbor-changes
 network 192.168.0.0 mask 255.255.0.0
 neighbor 10.0.8.254 remote-as 200
This seem work but i want to exclude for advertising one subnetwork (192.168.8.0/24 for example) for example.
is possible? How?
Thanks!
Martín.
Hi Martin,
router bgp 100
is possible? How?
Yes, it is possible. One way of excluding is using prefix-lists and route-map. Here is an example.
ip prefix-list  EXCLUDE_ADDRESS seq 5 deny 192.168.8.0/24 le 32
ip prefix-list  EXCLUDE_ADDRESS seq10 permit 192.168.0.0/16 le 32
route-map ADVERTISE_TO_NEIGHBOR permit 10
match ip address prefix-list EXCLUDE_ADDRESS
router bgp AS_NUMBER
neighbor X.X.X.X route-map  ADVERTISE_TO_NEIGHBOR out
HTH,
Meheretab
HTH,
Meheretab
8 Replies 8
Hi Martin,
router bgp 100
is possible? How?
HTH,
Meheretab
HTH,
Meheretab
Just adding to the previous post, if you have more networks to advertise, include this line:
ip prefix-list  EXCLUDE_ADDRESS seq 15 permit 0.0.0.0/0 le 32
The line will allow everything else.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
  Thanks all for reply,
  Meheretab, i don't understand this:
I must to put this command:
but instead if i make this command :
  neighbor 10.0.8.254 route-map  ADVERTISE_TO_NEIGHBOR out
I don't specify the AS. I'm right?
Martin,
You will need both commands: the first one is to create a neighbor relationship and the latter one is to filter routes to a particular neighbor. The complete command should have something like this:
router bgp 100
HTH,
Meheretab
HTH,
Meheretab
  Great! i gonna try it. Thanks for all.
Have a nice day!
Martín
Yes, this line: neighbor 10.0.8.254 remote-as 200  is mandatory because it is creating the BGP peering otherwise you will lose connection to that peer via BGP. Now this line is a complement for filtering:
Georg Pauwen
on a side note, and as an alternative to Julio's and Meheretab's solutions, you could also configure the below. The aggregate address by defaults sends all more specific networks, and the suppress map filters those specified in the respective route map...
router bgp 100
aggregate-address 192.168.0.0 255.255.0.0 suppress-map SUPPRESS
ip prefix-list SPECIFIC seq 5 permit 192.168.8.0/24
route-map SUPPRESS permit 10
match ip address prefix-list SPECIFIC
Hello
Caution should be taken when aggregating in BGP as it can lead to loops if you are not careful, due to the fact routing information can be lost on the advertised aggregate, As by default not only are you hiding the more specific routes you are also hiding AS numbers which are use in bgp to prevent loops!
res
Paul
Kind Regards
Paul
