Configuring fa1/0 on a router - Basic!!
JulianLeach2021
Visitor
Am doing some beginner labwork and am stumped on something that has to be really simple.....hasnt it!
I can configure ip addresses in router port f0/0 & 0/1 not a problem using the following series of commands
However when I try to do exactly the same for fa 1/0 I get this
The ‘?’ help menus at the route of the ‘int’ config are different too
Then on this interface
Why is this?   Banging my head against this for a while now
This is what my network looks like -
2 Accepted Solutions
Giuseppe Larosa
Hello Julian,
the fa1/0 is part of an etherswitch module and so it behaves like a L2 switch port ( note the switchport command)
You may have two options:
a)
int fas1/0
! the following command changes the port to a routed port
no switchport
ip address .......
b)  USe an SVI
interface vlan 1
ip address x.x.x.x 255.255.255.0
no shut
int fas1/0
switchport
switchport mode access
One of the two methods should work
Hope to help
Giuseppe
Hello
it may be a pure l2 interface as such you would need to create a L3 vlan SVI interface as suggest by Giuseppe and assign the vlan to that interface.
Kind Regards
Paul
6 Replies 6
Hello
Looks like that interface is a Layer 2 interface at present, try the following:
int fa1/0
no switchport
Kind Regards
Paul
Giuseppe Larosa
Hello Julian,
a)
int fas1/0
no switchport
ip address .......
b)  USe an SVI
interface vlan 1
no shut
int fas1/0
switchport
Hope to help
Giuseppe
JulianLeach2021
Visitor
Hi Paul
Thanks for the reply.   Though that would be it however can you comment futher?
I have completed as the solution
However i have this now as output.  I must be missing something!!!
Router>en
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#int fas 1/0
Router(config-if)#no sw
Router(config-if)#no switchport
% Incomplete command.
Router(config-if)#
Really very much appreciate your help and already happy that i know the interface can be configured!!
Cheers
Julian
Hello Julian,
if no switchport does not work you need to use an SVI interface VLAN where you put the IP address that is option b) in my previous answer.
Be aware that Vlan 1 is default.
If you use VLAN x
then you need
inteface fas1/0
switchport
switchport access vlan x
Hope to help
Giuseppe
Thanks ever so much for your help. Is there a reason why the 'no
switchport' command does not work?
Thanks again
Hello
Kind Regards
Paul
