connecting OC48 Between ASR9K and ASR1K
CATYO
Hi there.
I don't know the first thing about the  WAN something like POS...
Now I'm facing some problem with connecting OC48(POS) between ASR9K and ASR1K.
There are new 9K and new 1K  in same server rack for the test.
So i tried to test these for connecting OC48
9K and 1K is directly connected by OC48
9K : A9K-SIP-700 // SPA-2XOC48POS/RPR    // SFP-OC48-SR
1K : ASR1000-SIP10 // SPA-1XOC48-POS    // SFP-OC48-SR
After connecting these two devices directly, ASR1K shows the interface status is up/up
but ASR9K ... the interface status is down/down.
I didn't configure anything. Do i need to configure something ?
When i connected POS port 1 and POS port 2 directly in the same ASR 9K chassis, the interface is up/up
please help me out
Thank you in advance. :)
vmiller
Level 7
Level 7
Did you connect the transmit of one device to the receive of the other?
Hello.
Sorry I can't understand what you mean.
I just connected
ASR9K--------OC48------------ASR1K
directly.
There's no device between ASR9K and ASR1K.
exactly, so the transmit side of the 9k needs to be connected to the receive side of the 1k.
the transmit side of the 1k needs to be connected to the receive side of the 9k.
download this doc for reference:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/shared_port_adapters/install_upgrade/ASR1000/asr_sip_spa_hw/ASRsov.html#pgfId-1136398
Another link discussing the type of testing you are attempting:
http://www.cisco.com/c/en/us/support/docs/optical/synchronous-optical-network-sonet/16181-posclocking-16181.html
