Connection VPN
rechard_david
Dear All,
Could you tell me!!!
I have ASA 5510 and two Pix 515 and i also connect VPN. On the ASA on Port E0/0 connect to ISP1 and E0/1 connect to Lan and Port E0/2 connect to ISP2.So The VPN connect to ISP1 to site A is OK but The ISP 2 connect to Site B it doesn't work.
Do you have advice for me ? and Do you have any document for tell one ASA one port connect to one site and other port connect to other site.
Please see in the attach file..
hi rechard
What is the destination addresses for the second tunnel. as per the configuration i think it might be 192.168.2.0 series.
If it is 192.168.2.0 series then add the follow route.
route online 192.168.2.0 255.255.255.0 10.10.10.10
I think firewall is taking the outside interface path when you are establishing the second tunnel.
CiscogeekIND
route outside 0.0.0.0 0.0.0.0 10.10.10.10
I think this route should be route online 0.0.0.0 0.0.0.0 10.10.10.10.
And everything seems to be fine.
Rate the helpful posts.
Dear Sir and All,
i'm glad to hear from you!!!:)
i changed the route already but it still the problem...Do you have any command for advice?
i chenged like below:
I worry about this problem because my branch nearly open soon so it stil doesn't work.
Could you help me to solve this issue?
Best Regards,
Rechard
hi rechard
Dear Sir,
Yes, you correct the IP:192.168.2.0 is second tunnel( link to interface name online)
OK, i will be add this command route online 192.168.2.0 255.255.255.0 10.10.10.10 on ASA ( in HQ) and will be let you know.
Best Regards,
Rechard
