construction a PPPoE server for test
tomo456
Level 2
Level 2
I plan to construct 2 routers which connect with IPsec(Internet-VPN).
Therefore, I would like to construct a PPPoE server with [Cisco router] and confirm that [Router A] and [Router B] are configured correctly.
Network topology like this.
[Router A]-[Cisco router]-[Router B]
Could you create "running-config" ?
●Router A
LAN IP: 192.168.0.1/24
WAN IP: 1.1.1.1
●Router B
LAN IP: 192.168.1.1/24
WAN IP: 2.2.2.2
●both routers
Pre-shared key: test
encryption : aes-cbc
Authentication : sha-hmac
Protocols to allow on both routers: 5000 / tcp, 6000 / tcp
6 Replies 6
Georg Pauwen
it is unclear what you are asking: do you need a site to site VPN between Router A and Router B ? A PPPoE server would be something different...
In a test environment, I want to make the PPPoE server have the role of INTERNET and verify the setting of 2 routers.
・production environment
[Router A]-[INTERNET]-[Router B]
・test environment
here is a generic sample config:
Server (Internet)
username admin password cisco
bba-group pppoe global
virtual-template 1
interface GigabitEthernet0/0
ip address 10.10.10.1 255.255.255.0
load-interval 30
duplex auto
speed auto
pppoe enable group global
interface Virtual-Template1
mtu 1492
ip unnumbered GigabitEthernet0/0
peer default ip address pool PPPoE_POOL
ppp authentication pap chap
ip local pool PPPoE_POOL 192.168.1.1 192.168.1.200
Clients (Router A and Router B)
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
ip tcp adjust-mss 1452
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp pap sent-username admin password cisco
ppp chap hostname admin
ppp chap password cisco
ip route 0.0.0.0 0.0.0.0 Dialer1
janebutt1337
Community Member
On [Cisco Router]:
  • Configure interface: interface <interface_name>, ip address <ip_address> <subnet_mask>
  • Enable PPPoE server: vpdn enable, vpdn-group 1, request-dialin, protocol pppoe
  • Create virtual template: interface Virtual-Template1, ip unnumbered <interface_name>, ppp authentication pap chap, ppp ipcp dns request
On [Router A]:
  • Configure PPPoE client: interface Dialer1, ip address negotiated, ip mtu 1492, ip nat outside, encapsulation ppp, dialer pool 1, dialer-group 1, ppp authentication pap callin, ppp pap sent-username <username> password <password>
On [Router B]:
Note: Adapt the configuration to your specific network setup and Ciso router model. CEO of Budgeting Enterprise
alphaghostt757
Community Member
Interessante compartilhar esse guia sobre a construção de um servidor PPPoE para testes. Para quem também está planejando projetos domésticos, uma calculadora escada projeto pode ajudar a estimar medidas e detalhes importantes de maneira prática. Vale a pena conferir para otimizar tempo e recursos em projetos de construção.
darktitan646
Community Member
Setting up a test PPPoE server can get tricky without monitoring your energy intake while working long hours. For a more balanced routine, I’ve found the Calorie burn tracker really helpful to estimate daily calories and stay on track. It also helps in planning meals efficiently, ensuring you maintain focus and productivity during intensive tasks. Small adjustments in diet can surprisingly improve concentration while handling complex setups.
