Counting CRC errors via EEM for DSL modem?
MaseBarnes
I'm using a Cisco 886VA connected to an ADSL2+ line.
Typing "sh controll vdsl 0 | inc Err" shows me the CRC errors on the line, but the CRC error counter displayed with "sh int atm 0" is empty.
Also with 876 typing "sh dsl int atm 0" I can see growing error rate but "sh int atm 0" is empty.
I want to write an applet to reset the interface/controller if threshold is too high but the event interface detector won't see any errors.
Any ideas?
MB
andrew.prince
Level 10
Level 10
There must be an snmp mib value for what you want, find the oid then write your EEM script around that oid looking for the high/low.
HTH>
andrew.prince
Level 10
Level 10
HTH>
Nice hint! I did a walk from a linux before but can't find the enty, after loading some MIB's from Cisco I finally found it:
SNMPv2-SMI::transmission.94.1.1.10.1.4.15 = Counter32: 14633
SNMPv2-SMI::transmission.94.1.1.11.1.4.15 = Counter32: 14633
MB
