creating policy maps
larry.govedich
Frequent Visitor
Frequent Visitor
                   when creating policy maps I wanted to understand the difference between the following statements:
policy-map name
class name
police or priority
My question is what is the difference between these two commands.
cadet alain
police is for policing traffic that is restrain it to a certain bandwidth consumption at all times
priority is only in action when there is congestion and it tells to give priority to this traffic and police it to the value stated in the command.
Regards..
Alain
police: The router throws everything away that is above the configured rate.
priority: If there is a congestion on the interface, the router throws everything away that is above the configured rate. The traffic that stays below the configured rate gets priority.
Priority is typically used to protect important traffic like voice. Police is used to restrict the traffic that uses too much ressources and that can't be controlled in a different way.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
The priority command sends traffic to a single queue, the low latency queue (LLQ).  You can have more than one class defined with priority, but what that does is rate limit each class independently as the traffic is queued into the single LLQ.  As the other posters have noted, the implicit policer only engages if there's congestion.  It also drops traffic, when it's active, that exceeds its rate limit.
A police statement is a rate limiter added to a policy map class; even a priority class.  Unlike a priority class's implicit policer, it's always active.  It's more flexible than a priority class's implicit policer as you can adjust Bc and Be, often configure average or peak measurement, and define different actions for traffic that's within rate, overrate and very much overrate (features available may vary per IOS/platform).  (Note: a policer doesn't have to always discard overrate traffic, it might just mark it differently.)
Also, priority is an egress only policy feature.  A policer can be use on ingress or egress policy.
