creating small WAN
johnnycisc0
Hi all,
I have been tasked with installing a small WAN through 3 sites all connected via wireless bridging. Each site has an 831 router and a 2950 switch. Anyway I was wondering how I can go about structuring the IP addressing, can I set up the 831 router to act as a dhcp server for pc's that connect to the 2950 switch?? Also will all e0 ports have to be on the same range??
Thanks in advance.
umedryk
Level 5
Level 5
Yes, you could configure 2950 as your DHCP server
