creating Vlan
Davano123
Community Member
Hallo all,
i just watched this movie
http://www.youtube.com/watch?v=edCzr5L4Zec
and i now understand how i can sing a port to a vlan, but have one question.
Iff i have a port lets say: fa 0/4 and that is connected to a AP, and on the AP there 2 Vlan's. how do i sing the port fa 0/4 to Vlan 30 and 40 at the same time ?
If i need to give more info, then let me no.
Greets Davano
4 Accepted Solutions
John Blakley
You would create 2 vlans (30 and 40) on the switch. Then trunk the port that the AP connects to. By default, Cisco switches allow all vlans on the trunk, so you'd see vlan 1,30, and 40.
The AP would be configured with vlans 30 and 40 and would tag its traffic accordingly.
HTH,
John
*** Please rate useful posts ****
HTH, John *** Please rate all useful posts ***
Sandeep Choudhary
HI
Use like this.
first create vlan 30 and 40.
Switch#Config t
Switch(config)#vlan 30
Switch(config-vlan)#name WLAN1
Switch#Config t
Switch(config)#vlan 40
Switch(config-vlan)#name WLAN2
configure port like this:
Switch#Config t
Switch(config)#Int fa0/4
Switch(config-if)#description *** Connection to AP ***
Switch(config-if)Switchport mode trunk
Switch(config-if)#switchport trunk allowed vlan 30,40
Please rate if it helps.
The command is not ip dhcp network
it is ip dhcp pool
see eaxmple below:
ip dhcp excluded-address 20.0.0.1
ip dhcp pool test
   network 20.0.0.0 255.0.0.0
   default-router 20.0.0.1
In this case the name of the pool is test
Check the following document:
https://supportforums.cisco.com/community/help#discussions_correct
You can mark/select one or more reply as correct by clicking on the 'Correct Answer' button shown below.
Note: This 'Correct Answer' button will be only visible/available to the poster of the question.
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
10 Replies 10
John Blakley
HTH,
John
Thanks for the reply,
Than i now what i have to do, thanks again.
Greets Davano
Sandeep Choudhary
HI
Use like this.
Switch#Config t
Switch#Config t
Switch#Config t
have it working, but have one more quiestion about a router.
I trying to make a dhcp server on the router for a vlan, the commends i used are:
Router>enable
Router#conf t
Router(config)#ip dhcp ex
Router(config)#ip dhcp excluded-address 20.0.0.1
Router(config)#ip dhcp pool servers
Router(dhcp-config)#default-router 20.0.0.1
Router(dhcp-config)#network 20.0.0.0 255.0.0.0
Router(dhcp-config)#lease 0 23
when is use the commend:
it gives me a ^ below the l, and the when i change the server to dhcp i will get a ip end subnetmask,
but it wont get a gateway, what did i do worng
this is my config file from the router:
Router1#sh run
Building configuration...
Current configuration : 1072 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname Router1
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
enable password 7 0802455D0A16
username Test password 7 0822455D0A16
ip domain-name test.nl
interface FastEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.5
encapsulation dot1Q 5 native
ip address 5.0.0.1 255.0.0.0
interface FastEthernet0/1.10
encapsulation dot1Q 10
ip address 10.0.0.1 255.0.0.0
interface FastEthernet0/1.20
encapsulation dot1Q 20
ip address 20.0.0.1 255.0.0.0
interface FastEthernet0/1.30
encapsulation dot1Q 30
ip address 30.0.0.1 255.0.0.0
ip classless
banner login ^CThis is the login banner^C
banner motd ^CThis in the message of the day^C
logging 10.0.0.1
line con 0
login
line vty 0 4
login local
transport input ssh
end
Router1#
Greets
Hello Davano,
So are you saying the DHCP provides an IP to the end users but it does not provide a default gateway?
Hmm the configuration looks good. just to make sure it should be
ip dhcp pool Servers
exit
Can you configured it one more time and try to get an IP?
Julio
Julio Carvajal
Thanks for the reply.
yes the and user wont get a gateway, but i wil try it like you sad, will post te results in a few min?
but again thanks for the reply.
Greets
it looks like there is somthing wrong with packer tracer,
when i do
Router1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router1(config)#ip dhcp network servers
i get a ^ at the n from network
Greets
it is ip dhcp pool
see eaxmple below:
ip dhcp pool test
Tanks all for the reply's.
It is indeed:
ip dhcp pool test
today i did it on a real router, en than the end users do get the gateway, so it works.
and again all thanks for the help
one more question where do i sad the question to answered ?
Greets
Julio Carvajal
done
Greets
