CSR1000v in Azure - BFD Configuration
qasimhanif
Has anybody implemented Bidirectional Forwarding Detection BFD on CSR1000v in MS Azure environment?
Upon testing failover I found, the default gateway did not update on UDR
Any support or technical input would be much appreciated, can provide further info if required
Apologies if this is in the wrong category
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/azu/b_csr1000config-azure/b_csr1000config-azure_chapter_01001.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
mashrafi
Do you have any kind of logs or proof?
Is it possible to share your configuration?
