Curious problem with Point to Point T1
marviosantos
Hello all, first post here, and a CISCO newbee!!
I have two sites with a dedicated, point to point, LAN, site 1 has a Cisco 1700, LAN IP: 192.168.0.101; Site 2 has a Cisco 1800, LAN IP: 192.168.1.101.
From site 2 I can ping the router on the other side: 192.168.0.101, but nothing else on that network
From Site 1 I can't ping the other network at all
Both sites ping fine to their respective local interfaces. I also noticed, when trying to ping site 2 from 1, the  "WIC ACT/CH" light blinks, otherwise it's off.
Site 1 has it's own web connection through COMCAST, site 2 is set to route through site's 1 connection to go out. The only thing the routers are doing are the actual connection between sites, and in the case of site 2, routing web traffic to 192.168.0.100, which is a Sonicwall on Site 1.
This was all working just fine, for a long time, up until yesterday, when the problem I described started happening.
Any ideas?
letsgomets
Marvio
What is the subnet mask for both interfaces?
Can you include "show ip route" output?
