CyberLab
Noob22
Frequent Visitor
Frequent Visitor
Team please help this Noon;
I am unable to ping
From Router 2 I cannot ping 3.3.3.4
From Router 3 I cannot ping 4.4.4.4
From Router 3 I cannot ping 2.2.2.3
From Router 4 I cannot ping 3.3.3.3
I have attached the configuration I did and below are the IP routes. please help.
ROUTER 1
#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
Gateway of last resort is not set
2.0.0.0/32 is subnetted, 3 subnets
O IA 2.2.2.1 [110/782] via 10.1.1.2, 4w2d, Serial0/0/0
O 2.2.2.2 [110/782] via 10.1.1.2, 4w2d, Serial0/0/0
O IA 2.2.2.3 [110/782] via 10.1.1.2, 4w2d, Serial0/0/0
3.0.0.0/32 is subnetted, 1 subnets
B 3.3.3.3 [200/0] via 11.1.1.3, 1w6d
4.0.0.0/32 is subnetted, 1 subnets
O IA 4.4.4.4 [110/1563] via 10.1.1.2, 1w6d, Serial0/0/0
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.0.0.0/8 is directly connected, Serial0/0/0
L 10.1.1.1/32 is directly connected, Serial0/0/0
11.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 11.0.0.0/8 is directly connected, Serial0/0/1
L 11.1.1.1/32 is directly connected, Serial0/0/1
12.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
O IA 12.0.0.0/8 [110/2343] via 10.1.1.2, 1w6d, Serial0/0/0
O IA 12.1.1.0/24 [110/1562] via 10.1.1.2, 1w6d, Serial0/0/0
192.168.40.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.40.0/24 is directly connected, GigabitEthernet0/0
L 192.168.40.1/32 is directly connected, GigabitEthernet0/0
S 192.168.50.0/24 [1/0] via 10.1.1.2
ROUTER 2
#show IP route
C 2.2.2.1 is directly connected, Loopback1
C 2.2.2.2 is directly connected, Loopback0
C 2.2.2.3 is directly connected, Loopback3
O 4.4.4.4 [110/782] via 12.1.1.4, 1w6d, Serial0/0/1
L 10.1.1.2/32 is directly connected, Serial0/0/0
B 11.0.0.0/8 [200/0] via 10.1.1.1, 1w6d
12.0.0.0/8 is variably subnetted, 3 subnets, 3 masks
B 12.0.0.0/8 [20/0] via 12.1.1.4, 1w6d
C 12.1.1.0/24 is directly connected, Serial0/0/1
L 12.1.1.2/32 is directly connected, Serial0/0/1
S 192.168.40.0/24 [1/0] via 10.1.1.1
192.168.50.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.50.0/24 is directly connected, GigabitEthernet0/0
L 192.168.50.1/32 is directly connected, GigabitEthernet0/0
ROUTER 3
#show ip route
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
2.0.0.0/32 is subnetted, 2 subnets
B 2.2.2.1 [200/0] via 10.1.1.2, 1w6d
B 2.2.2.2 [200/0] via 10.1.1.2, 1w6d
3.0.0.0/32 is subnetted, 2 subnets
C 3.3.3.3 is directly connected, Loopback0
C 3.3.3.4 is directly connected, Loopback1
B 10.0.0.0/8 [200/0] via 11.1.1.1, 1w6d
C 11.0.0.0/8 is directly connected, Serial0/0/0
L 11.1.1.3/32 is directly connected, Serial0/0/0
ROUTER 4
#show ip route
B 2.2.2.1 [20/0] via 12.1.1.2, 1w6d
B 2.2.2.2 [20/0] via 12.1.1.2, 1w6d
O 2.2.2.3 [110/782] via 12.1.1.2, 1w6d, Serial0/0/0
B 3.3.3.3 [20/0] via 12.1.1.2, 1w6d
C 4.4.4.4 is directly connected, Loopback0
B 10.0.0.0/8 [20/0] via 12.1.1.2, 1w6d
B 11.0.0.0/8 [20/0] via 12.1.1.2, 1w6d
C 12.0.0.0/8 is directly connected, Serial0/0/0
O 12.1.1.0/24 [110/1562] via 12.1.1.2, 1w6d, Serial0/0/0
L 12.1.1.4/32 is directly connected, Serial0/0/0
8 Replies 8
pieterh
compare this to L 12.1.1.4/32 is directly connected, Serial0/0/0
there is something wrong here..... a /32 network cannot be subnetted !
this may be a bug in the emulator/simulator you are using?
Hello
FYI -That is a local connected host, so it is correct.
Serial 0/0/0 on that rtr has an ip address of 12.1.1.4  attached to ospf relating to a subnet of 12.1.1.0/24.
Kind Regards
Paul
Georg Pauwen
if this is a Packet Tracer project, post the zipped project (.pkt) file, otherwise, post the full running configurations of all four routers.
ROUTER 1
Building configuration...
Current configuration : 2131 bytes
! Last configuration change at 14:33:34 UTC Tue Apr 20 2021
! NVRAM config last updated at 14:33:36 UTC Tue Apr 20 2021
version 15.1
hostname RTR01
boot-start-marker
boot-end-marker
enable secret 4
enable password
no aaa new-model
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO1941/K9 sn FTX1550828U
license boot module c1900 technology-package securityk9
redundancy
interface Loopback99
 no ip address
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 192.168.40.1 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0/0
 ip address 10.1.1.1 255.0.0.0
 clock rate 64000
interface Serial0/0/1
 ip address 11.1.1.1 255.0.0.0
 clock rate 64000
router ospf 100
 network 10.0.0.0 0.255.255.255 area 0
router rip
 network 192.168.40.0
router bgp 100
 bgp log-neighbor-changes
 network 10.0.0.0
 network 11.0.0.0
 neighbor 10.1.1.2 remote-as 100
 neighbor 10.1.1.2 route-reflector-client
 neighbor 11.1.1.3 remote-as 100
 neighbor 11.1.1.3 route-reflector-client
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.50.0 255.255.255.0 10.1.1.2
logging trap debugging
logging 192.168.40.31
snmp-server community router_1 RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server host 192.168.40.31 router_1
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password
 login
 transport input all
scheduler allocate 20000 1000
end
ROUTER 2
Current configuration : 2148 bytes
! Last configuration change at 16:29:33 UTC Thu Apr 15 2021
! NVRAM config last updated at 16:29:39 UTC Thu Apr 15 2021
version 15.1
hostname RTR02
boot-start-marker
boot-end-marker
enable secret
enable password
no aaa new-model
no ipv6 cef
ip source-route
ip cef
license udi pid CISCO1941/K9 sn FTX1550826T
redundancy
interface Loopback0
 ip address 2.2.2.2 255.255.255.255
interface Loopback1
 ip address 2.2.2.1 255.255.255.255
interface Loopback3
 ip address 2.2.2.3 255.255.255.255
 no ip address
 shutdown
 ip address 192.168.50.1 255.255.255.0
 duplex auto
 speed auto
 no ip address
 shutdown
 duplex auto
 speed auto
 ip address 10.1.1.2 255.0.0.0
 ip address 12.1.1.2 255.255.255.0
router ospf 100
 network 2.2.2.1 0.0.0.0 area 1
 network 2.2.2.2 0.0.0.0 area 0
 network 2.2.2.3 0.0.0.0 area 1
 network 12.0.0.0 0.255.255.255 area 1
router rip
 network 192.168.50.0
router bgp 100
 network 2.2.2.1 mask 255.255.255.255
 network 2.2.2.2 mask 255.255.255.255
 network 10.0.0.0
 network 12.0.0.0
 neighbor 10.1.1.1 remote-as 100
 neighbor 12.1.1.4 remote-as 200
no ip http server
ip route 192.168.40.0 255.255.255.0 10.1.1.1
control-plane
line con 0
line aux 0
line 2
 no exec
 transport input all
 stopbits 1
line vty 0 4
 password
 login
 transport input all
end
ROUTER 3
Current configuration : 1631 bytes
version 15.7
hostname RTR03
boot-start-marker
boot-end-marker
enable secret
enable password
no aaa new-model
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1630ANLD
redundancy
interface Loopback0
 ip address 3.3.3.3 255.255.255.255
interface Loopback1
 ip address 3.3.3.4 255.255.255.255
 no ip address
 shutdown
 no ip address
 shutdown
 duplex auto
 speed auto
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
 ip address 11.1.1.3 255.0.0.0
 no ip address
 shutdown
 clock rate 125000
router ospf 100
 network 3.3.3.4 0.0.0.0 area 0
 network 11.0.0.0 0.255.255.255 area 0
router bgp 100
 network 3.3.3.3 mask 255.255.255.255
 neighbor 11.1.1.1 remote-as 100
no ip http server
ipv6 ioam timestamp
control-plane
vstack
line con 0
line aux 0
line 2
 no exec
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password
 login
 transport input none
End
ROUTER 4
Current configuration : 1855 bytes
version 15.7
hostname RTR04
boot-start-marker
boot-end-marker
enable secret 5
enable password
no aaa new-model
ip cef
no ipv6 cef
voice-card 0
vxml logging-tag
license udi pid CISCO2911/K9 sn FTX1509A18B
license boot module c2900 technology-package uck9
redundancy
interface Loopback0
 ip address 4.4.4.4 255.255.255.255
 no ip address
 shutdown
 no ip address
 shutdown
 duplex auto
 speed auto
 no ip address
 shutdown
 duplex auto
 speed auto
 no ip address
 shutdown
 duplex auto
 speed auto
 ip address 12.1.1.4 255.0.0.0
 clock rate 125000
 no ip address
 shutdown
 clock rate 125000
router ospf 100
 network 4.4.4.4 0.0.0.0 area 1
router bgp 200
 network 12.0.0.0
 neighbor 12.1.1.2 remote-as 100
no ip http server
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
 shutdown
 vstack
line con 0
line aux 0
line 2
 no exec
 stopbits 1
line vty 0 4
 password
 login
end
Hello;
I have posted the config.
post the zipped Packet Tracer project (.pkt) file...
I dont have that.
Hello
First of all this is a dulipcate post with this - OSPF-BGP misconfiguration
Can you confirm the configuration you have shared is supposed to be this way or is it what you have applied to try and obtain connectivity, Thew reason Im am asking is the current applied configuration doesn’t make sense.
All rtrs have both ospf and bgp running and each rtr is adverting separate networks and in some cases in different areas, even with mutual redistribution it still would be messy.
Example:
r3-r1 just ibgp is peering
r1-r2 ospf and ibgp peering
r2-r4 just ebgp peering
Kind Regards
Paul
