DCT DTE crossover Cable
getdan
Level 3
Level 3
How do I make A DTE to DCE crossover cable? I am connecting two WIC1 DSU T1 cards in a lab for frame-relay
So have you tried the new cable yet ?
14 Replies 14
pkhatri
Level 11
Level 11
Connect pins 1,2 from one cable to pins 4,5 of the other. Also connect ping 4,5 from the first cable to pins 1,2 of the second.
Here's a summary:
1 --- 4
2 --- 5
4 --- 1
5 --- 2
Hope that helps - pls rate the post if it does.
Paresh
Thats what I had but I still can't get the frame links to come up.
Is it the physical layer that's not coming up ? If the controller is coming up, but the link-layer (frame-relay) is not coming up, the cabling is not the issue.
Would you be able to post the output of 'sh controller t1 xxx' ?
One other thing, if you are using frame-relay, configure 'frame-relay intf-type dce' under the serial interface at one end. That will allow the link-layer to come up.
Paresh
Here are the configs of the three routers in the config. nothing comes up with sh controllers t1
Would you be able to post the output of 'sh controller Serial0/0' from RouterA please ?
Paresh
Here u go
I think we are getting closer... Could you pls post the output of 'show service-module serial0/0' from routerA and also for the serial port which it connects to on the FRswitch ?
Paresh
Thank you so much for your help... Is it clocking? Both set to line..
Clocking is certainly an issue but you've got a bigger issue to deal with before then. Both interfaces are showing loss of signal, so your cable is the problem.
Could you post the output of 'sh ver' and 'sh diag' from your routers ?
Thanks.
Actually, could you try the following cross-over cable.. I've seen this being used on some occasions...
1 --- 5
2 --- 4
4 --- 2
5 --- 1
Paresh
RouterA is up for now but seems to go back down after while.
Just got done redoing both cables
1--4
2--5
4--1
5--2
both side of the frame are now up.
looks like I made some bad cables to begin with.
Thank you for youur help. Sorry to have put you thgough this for nothing..
Pleasure to be of assistance... You had me scratching my head there for a while - had to be cabling !
Paresh
