Default routing not working
ashararitesh
Frequent Visitor
Frequent Visitor
Hello all,
Default routing not working in WS-C2960X-24TS-L, as below configuration.
Switch Ports Model SW Version SW Image
* 1 30 WS-C2960X-24TS-L 15.2(7)E0a C2960X-UNIVERSALK9-M
Configuration register is 0xF
Switch#show run
Building configuration...
Current configuration : 1867 bytes
! Last configuration change at 09:40:13 UTC Mon Mar 21 2005
version 15.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c2960x-24ts-l
ip routing
spanning-tree mode rapid-pvst
interface FastEthernet0
no ip address
no ip route-cache
shutdown
interface GigabitEthernet1/0/1
switchport access vlan 20
switchport mode access
interface GigabitEthernet1/0/2
switchport access vlan 100
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
no ip address
shutdown
interface Vlan20
ip address 10.0.20.36 255.255.255.0
interface Vlan100
ip address 192.168.100.1 255.255.255.0
ip default-gateway 10.0.20.251
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.0.20.251
line con 0
line vty 5 15
end
Switch#ping 4.2.2.2
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 266/269/273 ms
Switch#
Note : Inter vlan routing successfully but vlan 100 internet not working
15 Replies 15
ashararitesh
Frequent Visitor
Frequent Visitor
Switch#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 10.0.20.251 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 10.0.20.251
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.0.20.0/24 is directly connected, Vlan20
L 10.0.20.36/32 is directly connected, Vlan20
192.168.100.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.100.0/24 is directly connected, Vlan100
L 192.168.100.1/32 is directly connected, Vlan100
Switch#
Georg Pauwen
I assume the device with IP address 10.0.20.251 is doing the NAT for your network ? Can you post the configuration of that device ?
it's sonicwall firewall, its interface ip address 10.0.20.251.
i can ping 4.2.2.2 from switch
its configured to NAT 192.168.100.0/24? No
I have 2960x switch and i give default route.
Seb Rupik
Hi there,
What device is 10.0.20.251 ? Does it know how to reach 192.168.100.0/24 ? Is it configured to NAT 192.168.100.0/24?
cheers,
Seb.
Its sonicwall firewall, its interface ip address 10.0.20.251.
s it configured to NAT 192.168.100.0/24? No
Everyone's tags (0)
as pointed out by Seb, the SonicWall needs to have a NAT entry for 192.168.100.0/24 and a route back to the L3 switch.
Check the NAT Policy Settings and the Route Policy Settings on your firewall...
Thanks for your reply,
When i tracert from my PC packet reach at gateway.
192.168.100.1 than its show unreachable.
What is the source IP of this ping, is it on the 10.0.20.0/24 subnet ?
If so the request will probably traveling to the sonicwall, which itself doesn't have a router for 192.168.100.0/24 .
I have 2960x & want to l3 switch.
can i configured NAT??
NAT is typically supported on routers and firewalls....and a few L3 switches, but not a 2960X!
NAT configured in firewall for 10.0.20.251.
When i give default route in switch means unknown traffic reach at 10.0.20.251 its correct?
But my question is default routing not working
I'd imagine NAT is configured for the entire 10.0.20.0/24 subnet not just a single IP.
As @paul driver mentions traffic arriving on the 2960X destined to non-connected subnet will be forwarded towards the sonicwall. For the sonicwall to send a response it needs to know that 192.168.100.0/24 is reachable via 10.0.20.36 .
For a device in VLAN100 to be routed beyond the sonicwall, then the sonicwall needs to permit NAT for the 192.168.100.0/24 subnet.
cheers,
Seb.
Hello
it won't work for two reasons:
1) your default route is pointing to vlan 20 so any attempt to reach a not connected prefix will be routed to vlan 20 not vlan 100
2) when you have pointed the default route towards vlan 100 then you will need a router/fw that is assigned that next hop ip address and is connected to vlan100 to be able to perform network translation for vlan 20 and 100 users
Kind Regards
Paul
