DHCH snooping
maulikp
Community Member
please help me to understand below commands
ip dhcp snooping vlan 32,36,40,44
no ip dhcp snooping information option
ip dhcp snooping
Regards & Thanks
Maulik
Julio E. Moisa
If you want to configure dhcp snooping properly follow these steps:
Step 1:
ip dhcp snooping = it will enable dhcp snooping globally on your device but it will not take any effect without the step 2.
Step 2:
ip dhcp snooping vlan X1,X2,X3...Xn = DHCP snooping will not work if you dont associate the vlans that you want to protect. (just ip dhcp snooping will not do nothing until the vlans are associated to it)
Step 3:
no ip dhcp snooping information option: The option 82 is added to the request to the DHCP server before to be forwarded. It could generated some inconsistency with relay information. You can see that executing a debug: debug ip dhcp server packet. Adding the no, it will disabled this option. Most of the case it is disabled.
Step 4
ip dhcp snooping limit rate: This is optional but recommended, to limit the packets per second. try to configure no more that 100. This is configured on the access port only, not under the trunk interfaces.
Step 5
ip dhcp snooping trust: This command line is configured under the trusted interfaces, in few words under the trunk interface where the broadcast will search the DHCP servers on the company network infrastructure.
This link can be useful: http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_35_se/configuration/guide/scg/swdhcp82.html#wp1070843
Hope it is useful  🙂
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
15 Replies 15
Francesco Molino
IP DHCP SNOOPING:
it will act like a FW between your hosts (untrusted) and your DHCP Servers (Trusted).
SNOOPING INFORMATION OPTION:
It is related to DHCP OPTION-82:
DHCP option 82 provides additional security when DHCP is used to allocate network addresses. It enables the controller to act as a DHCP relay agent to prevent DHCP client requests from untrusted sources.
SNOOPING VLAN:
Activate snooping security feature for particular vlans as per default all vlans are not activated with snooping capabilities.
Hope this more clear.
Thanks.
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
I'm not getting ip through dhcp at any laptop. Please help out, If u need any other configuration please let me know
CORE
ip dhcp pool TEN
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8
ip dhcp pool TWENTY
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
dns-server 8.8.8.8
ip routing
ip dhcp snooping vlan 10
ip dhcp snooping
interface Vlan10
mac-address 0060.5c40.e301
ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/1
switchport trunk allowed vlan 10,20
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan20
mac-address 0060.5c40.e302
ip address 192.168.20.1 255.255.255.0
interface Vlan100
mac-address 0060.5c40.e303
ip address 192.168.100.100 255.255.255.0
Sw2
ip dhcp snooping
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
interface FastEthernet0/11
switchport access vlan 20
interface Vlan100
mac-address 0002.4a81.5201
ip address 192.168.100.20 255.255.255.0
Sw1
ip dhcp snooping
interface FastEthernet0/10
interface Vlan100
mac-address 0001.42c3.e901
ip address 192.168.100.10 255.255.255.0
maulikp
Community Member
May this show command help us to resolve problem
CORE#show ip dhcp snooping
Switch DHCP snooping is enabled
DHCP snooping is configured on following VLANs:
DHCP snooping is operational on following VLANs:
none
Smartlog is configured on following VLANs:
none
Smartlog is operational on following VLANs:
none
DHCP snooping is configured on the following L3 Interfaces:
Insertion of option 82 is enabled
circuit-id default format: vlan-mod-port
remote-id: 0060.5C40.E369 (MAC)
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
Verification of giaddr field is enabled
DHCP snooping trust/rate is configured on the following Interfaces:
Interface Trusted Allow option Rate limit (pps)
GigabitEthernet0/1 yes yes unlimited
Custom circuit-ids:
GigabitEthernet0/2 yes yes unlimited
Custom circuit-ids:
CORE#
Sw2#
Sw2#show ip dh
Sw2#show ip dhcp s
Sw2#show ip dhcp snooping
Interface Trusted Rate limit (pps)
GigabitEthernet0/2 yes unlimited
Sw1#
Sw1#show ip dh
Sw1#show ip dhcp sn
Sw1#show ip dhcp snooping
GigabitEthernet0/1 yes unlimited
Sw1#
Julio E. Moisa
Step 1:
Step 2:
Step 3:
Step 4
Step 5
Hope it is useful  🙂
maulikp
Community Member
Still not get ip through dhcp
when i disable DHCP snooping using
no dhcp snooping
then i get the ip through DHCP
Please let me check the config below, also the ip dhcp snooping is usually configured on the access switches only.
Try to remove the DHCP snooping config on the Core device and leave it on the access switches only.
Still not working...
Ok, could you please provide me your configurations on txt file.
thank you in advance.
Hii
Thanks for responding and try to resolve my query .
Please find the attachment
You are welcome,
Please let me take a look.
This command is configured under the access ports only not under the trunks:
 ip dhcp snooping limit rate 3
please remove it from the interface trunk:
no ip dhcp snooping limit rate 3
And configure it under the access ports, for example:
int fa0/15
 ip dhcp snooping limit rate 50   (also try to increase the limit)
Hi..
still not working, may be packet tracer bugs.
I have to know if  i didn't allow vlan 100 in the trunk, i'm using this vlan as a MGMT. i configured ip routing commands on core switch. So, it is possible to ping MGMT ip.
Same configuration. actually one of my friend told me that in this situation u get the ping but u can't get data from MGMT vlan, so please help me to clear my doubt. and if possible to share some documents or your knowledge so i can understand how vlan traffic move in a network. and what is requirement to get ping and what is requirement to pass the traffic.
i  know my english is not that much good. so, please try to understand my que.
Thanks a lot
Regards Maulik
no worries 🙂
Yes you can add your management vlan to the trunk without inconveniences. To be honest I have not execute ip dhcp snooping on packet tracert. How I remember packet tracer has some command limitations but I dont know the recent versions hehehe.
Also you can use these commands to see the behavior, (in a real enviroment these commands should be applied after business hours:
switch# debug ip dhcp snooping event
switch# debug ip dhcp snooping packet
Also try to configure your trunks like this for testing purposes:
example:
switchport
no switchport trunk allowed vlan 10,20
