DHCP bindings database...Error
hi all ,
It is required to upload currently dhcp issued ip's to the remote ftp server. Because of this , I did the following configurations on my router.
ip dhcp database ftp://testuser:testuser@<ftp-server-ip>/router-dhcp write-delay 120
Once I issue the 'sh ip dhcp database' command obtained the following output.
URL       :  ftp://testuser:testuser@<ftp-server-ip>/router-dhcp
Read      : Never
Written   : Never
Status    :  Last write failed because of a protocol error.
Delay      : 120 seconds
Timeout  : 300 seconds
Failures  : 30
Successes: 0
I cannot figure out what is the reason for this. But I can assure my ftp server working fine and the ftpuser can write data to the particular directory. I have tow interfaces in my router. Because of this I need to provide souce interface as my LAN IP. How can define it during this command. For a example in syslog messages i defined the "logging source fa 0/0" command.
your responses are higly welcome in order to solve this.
cadet alain
Try ip ftp source-interface command.
Regards.
Alain.
cadet alain
Regards.
Alain.
hi cadet alain ,
Thanks for your reply. It worked fine for me .
