DHCP on Cisco 881 WAN interface
iholdings
Greetings,
I'm working with a service provider (Telus in Canada) that can only supply an IP address for my Cisco 881 WAN interface via DHCP.  I'm use to ordering business class DSL service with some number of static IP address to use.  In this case - I'm suppose to register the WAN interface MAC address on their site - which will in turn provide a static IP out of the DHCP pool.  So in essence - I should get a static IP via DHCP.
The problem I'm having is when I set the WAN interface as follows:
interface FastEthernet4
ip address dhcp
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip virtual-reassembly
duplex auto
speed auto
snmp trap ip verify drop-rate
I do not get an IP address.
They will not support this setup, but I don't know how or what the many possibilities there are for configuring the 881 to pull an IP address.
HELP!!
8 Replies 8
Brent Rockburn
Level 2
Level 2
Can we see the debug output
I've add to use their site to regirster mac addresses before as well .. it will show you what the IP will be. You might have to remove it and re add it.
Also as a test you can create a vlan interface and put one of the physical interfaces into that vlan and put the DHCP entries on that interface and try it as well.
Let me know what happens.
Sorry - I'm a bit of a noob.  I've never dealt with any other IP addressing other than applying statics.
How do I set up debug?
When you say remove and re-add - would that be removing and re-adding the MAC (for int Fa4) to the IP on the Telus site?
No worries man ... no worries at all ..
# debug dhcp detail
I meant remove it from the telus site and re add it.
Also, is it an older dsl modem? Because I've seen problems with that as well.
When you regirstered the MAC for fas4 did you get any errors?
I can send you what i used as a config if you'd like.
let me know
Bye for now.
A sample config would be great!!
I just went and removed/re-added the Fa4 MAC - got no errors (took defaults for Host Name and Domain) and got a completely different static address. reloaded the router - but still no IP.
Can I force a command to show debug output?
#term mon <-- This will send the output of your debug command to your terminal screen. use #term no mon to shut it off and use "#undebug all" to shut off the debug.
I'll send you the config as soon as I can find it, shouldn't be long.
Here's the debug output.  I really appreciate your help on this.  Very frustrating.
000897: *Nov 20 12:21:27.011 PCTime: DHCP: Try 3 to acquire address for FastEthernet4
000898: *Nov 20 12:21:27.011 PCTime: DHCP: allocate request
000899: *Nov 20 12:21:27.011 PCTime: DHCP: zapping entry in DHC_PURGING state for Fa4
000900: *Nov 20 12:21:27.011 PCTime: DHCP: deleting entry 85AC0D64 0.0.0.0 from list
000901: *Nov 20 12:21:27.011 PCTime: Temp IP addr: 0.0.0.0  for peer on Interface: FastEthernet4
000902: *Nov 20 12:21:27.011 PCTime: Temp  sub net mask: 0.0.0.0
000903: *Nov 20 12:21:27.011 PCTime:    DHCP Lease server: 0.0.0.0, state: 11 Purging
000904: *Nov 20 12:21:27.011 PCTime:    DHCP transaction id: 16DF
000905: *Nov 20 12:21:27.011 PCTime:    Lease: 0 secs,  Renewal: 0 secs,  Rebind: 0 secs
000906: *Nov 20 12:21:27.011 PCTime:    Next timer fires after: 00:00:21
000907: *Nov 20 12:21:27.011 PCTime:    Retry count: 0   Client-ID: cisco-0024.c40a.c0aa-Fa4
000908: *Nov 20 12:21:27.011 PCTime:    Client-ID hex dump: 636973636F2D303032342E633430612E
000909: *Nov 20 12:21:27.011 PCTime:                        633061612D466134
000910: *Nov 20 12:21:27.011 PCTime:    Hostname: Calgary
000911: *Nov 20 12:21:27.011 PCTime: DHCP: new entry. add to queue, interface FastEthernet4
000912: *Nov 20 12:21:27.011 PCTime: DHCP: SDiscover attempt # 1 for entry:
000913: *Nov 20 12:21:27.011 PCTime: Temp IP addr: 0.0.0.0  for peer on Interface: FastEthernet4
000914: *Nov 20 12:21:27.011 PCTime: Temp  sub net mask: 0.0.0.0
000915: *Nov 20 12:21:27.011 PCTime:    DHCP Lease server: 0.0.0.0, state: 3 Selecting
000916: *Nov 20 12:21:27.011 PCTime:    DHCP transaction id: 16E0
000917: *Nov 20 12:21:27.011 PCTime:    Lease: 0 secs,  Renewal: 0 secs,  Rebind: 0 secs
000918: *Nov 20 12:21:27.011 PCTime:    Next timer fires after: 00:00:04
000919: *Nov 20 12:21:27.011 PCTime:    Retry count: 1   Client-ID: cisco-0024.c40a.c0aa-Fa4
000920: *Nov 20 12:21:27.011 PCTime:    Client-ID hex dump: 636973636F2D303032342E633430612E
000921: *Nov 20 12:21:27.011 PCTime:                        633061612D466134
000922: *Nov 20 12:21:27.011 PCTime:    Hostname: Calgary
000923: *Nov 20 12:21:27.011 PCTime: DHCP: SDiscover: sending 294 byte length DHCP packet
000924: *Nov 20 12:21:27.011 PCTime: DHCP: SDiscover 294 bytes
000925: *Nov 20 12:21:27.015 PCTime:             B'cast on FastEthernet4 interface from 0.0.0.0
000926: *Nov 20 12:21:30.967 PCTime: DHCP: SDiscover attempt # 2 for entry:
000927: *Nov 20 12:21:30.967 PCTime: Temp IP addr: 0.0.0.0  for peer on Interface: FastEthernet4
000928: *Nov 20 12:21:30.967 PCTime: Temp  sub net mask: 0.0.0.0
000929: *Nov 20 12:21:30.967 PCTime:    DHCP Lease server: 0.0.0.0, state: 3 Selecting
000930: *Nov 20 12:21:30.967 PCTime:    DHCP transaction id: 16E0
000931: *Nov 20 12:21:30.967 PCTime:    Lease: 0 secs,  Renewal: 0 secs,  Rebind: 0 secs
000932: *Nov 20 12:21:30.967 PCTime:    Next timer fires after: 00:00:04
000933: *Nov 20 12:21:30.967 PCTime:    Retry count: 2   Client-ID: cisco-0024.c40a.c0aa-Fa4
000934: *Nov 20 12:21:30.967 PCTime:    Client-ID hex dump: 636973636F2D303032342E633430612E
000935: *Nov 20 12:21:30.967 PCTime:                        633061612D466134
000936: *Nov 20 12:21:30.967 PCTime:    Hostname: Calgary
000937: *Nov 20 12:21:30.967 PCTime: DHCP: SDiscover: sending 294 byte length DHCP packet
000938: *Nov 20 12:21:30.967 PCTime: DHCP: SDiscover 294 bytes
000939: *Nov 20 12:21:30.967 PCTime:             B'cast on FastEthernet4 interface from 0.0.0.0
000940: *Nov 20 12:21:34.967 PCTime: DHCP: SDiscover attempt # 3 for entry:
000941: *Nov 20 12:21:34.967 PCTime: Temp IP addr: 0.0.0.0  for peer on Interface: FastEthernet4
000942: *Nov 20 12:21:34.967 PCTime: Temp  sub net mask: 0.0.0.0
000943: *Nov 20 12:21:34.967 PCTime:    DHCP Lease server: 0.0.0.0, state: 3 Selecting
000944: *Nov 20 12:21:34.967 PCTime:    DHCP transaction id: 16E0
000945: *Nov 20 12:21:34.967 PCTime:    Lease: 0 secs,  Renewal: 0 secs,  Rebind: 0 secs
000946: *Nov 20 12:21:34.967 PCTime:    Next timer fires after: 00:00:04
000947: *Nov 20 12:21:34.967 PCTime:    Retry count: 3   Client-ID: cisco-0024.c40a.c0aa-Fa4
000948: *Nov 20 12:21:34.967 PCTime:    Client-ID hex dump: 636973636F2D303032342E633430612E
000949: *Nov 20 12:21:34.967 PCTime:                        633061612D466134
000950: *Nov 20 12:21:34.967 PCTime:    Hostname: Calgary
000951: *Nov 20 12:21:34.967 PCTime: DHCP: SDiscover: sending 294 byte length DHCP packet
000952: *Nov 20 12:21:34.967 PCTime: DHCP: SDiscover 294 bytes
000953: *Nov 20 12:21:34.967 PCTime:             B'cast on FastEthernet4 interface from 0.0.0.0
000954: *Nov 20 12:21:38.967 PCTime: DHCP: QScan: Timed out Selecting state%Unknown DHCP problem.. No allocation possible
Hello-
Any luck finding the sample config.?  It looks like I'm stuck with Telus - so any help would be most appreciated.
Thanks.
PerogyOverload
I realize this post is few months old at this point, but it comes up in a Google search for "telus cisco dhcp" which I came across today, so I thought I'd post my experience and hopefully some semblance of a resolution.
I was working on this same issue except with a Secure Router 520.  Before I registered the MAC address via http://registerdevice.telus.com, it grabbed a 10.137.x.x (non-externally routable) address (which is normal behaviour for Telus).  After registering the MAC address, it would not obtain an IP address what so ever.  Telus tech support insisted there was nothing wrong on their end, but couldn't explain why I got an address prior to registering, but not after.
After a lot of testing, what it boiled down to was this:
- it looks like Telus' DHCP servers are checking/enforcing the "hostname" parameter of a DHCP request in addition to the MAC address before handing out an IP.  Cisco's implementation of the DHCP client sends whatever the router has as its hostname if you just have "ip address dhcp" in the interface's config, unless you specify "ip address dhcp hostname " instead.
- other DHCP clients (such as in various Windows versions and other routers) have the option to also obtain the hostname from the DHCP server, which apparently Cisco's client won't do (or at least I can't find a way to make it do that).
- you can also set the hostname parameter in http://registerdevice.telus.com, or if you leave it blank it will auto-create one (something like S-17-xxx).
So, to resolve this issue (or, at least what worked for me):
a) in http://registerdevice.telus.com, make sure you register the *actual hostname* of your Cisco router (most likely it's also case-sensitive, although I didn't test that thoroughly) in addition to its MAC address.
or (not thoroughly tested by me)
b) make a note of what hostname was automatically generated for the router's MAC address in http://registerdevice.telus.com and change the router's external interface config to read "ip address dhcp hostname " (assuming you have a reasonably current IOS version - not sure exactly which version added the additional "ip address dhcp" syntax).
After I did step a) I ran "ip address dhcp" and immediately got the public "static" IP I was expecting.
Good luck!
