DHCP with multiple VLANs via SVI inter vlan routing.
noah5E
Hello all .
I'm trying to configure DHCP server in a c2911 router , to serve multiple VLAN (10 , 20)
(1) i created SVI interfaces in the MLSW1 and activated routing
(2) i turned interfaces (Fa0/1 , Fa0/2 , Fa0/3) to Trunk
i know i can do it by creating subinterfaces in the router , each as the default-gateway for each VLAN (ROAS)
but is there no way to configure this via SVI ? what i messed ?
MLSW2 config :
version 12.2(37)SE1
ip routing
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
switchport nonegotiate
interface FastEthernet0/2
switchport access vlan 20
switchport nonegotiateswitch
interface FastEthernet0/3
switchport mode trunk
interface Vlan1
no ip address
shutdown
ip classless
end
MLSW1 config :
version 12.2(37)SE1
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 00e0.a3e9.1301
ip address 10.0.0.1 255.255.255.0
ip helper-address 192.168.1.1
interface Vlan20
mac-address 00e0.a3e9.1302
ip address 20.0.0.1 255.255.255.0
end
router config :
version 15.1
hostname Router
ip dhcp excluded-address 10.0.0.1
ip dhcp excluded-address 20.0.0.1
ip dhcp pool VLAN_10
network 10.0.0.0 255.255.255.0
default-router 10.0.0.1
dns-server 8.8.8.8
ip dhcp pool VLAN_20
network 20.0.0.0 255.255.255.0
default-router 20.0.0.1
dns-server 8.8.8.8
interface GigabitEthernet0/0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
end
Thanks in advance
Hello
@noah5E wrote:
Hello all .
Yes, you just need to create the dhcp pool on the rtr and have a L3 connection between the rtr and switch, laslty on the switch SVI's append a ip helper address pointing to the rtr.
In your example please append the following and test again.
mlsw1
ip routing
int x/x
description toward RTR
ip address 192.168.1.2 255.255.255..0
ip route 0.0.0.0 0.0.0.0 <interface> 192.168.1.1
mlsw2
no ip routing
Kind Regards
Paul
Hello
@noah5E wrote:
Hello all .
mlsw1
ip routing
int x/x
mlsw2
no ip routing
Kind Regards
Paul
you have posted three configs, one of a L3 switch (ip routing enabled), one of a layer 2 switch, and one of a router. How are these devices connected, and what do you want to achieve ?
the main idea i want to achieve is to make devices in different VLANs to get ip from the DHCP server which is connected to the Core Layer
it would be helpful if you told me the main steps of the configs
here is the main topology :
