Dialer Interface Question
benolyndav
Level 8
Level 8
How do I check that all is ok with a Dialer Interface which is using Chap for authentication, is there any basic commands I can run to check all is ok, also I notice that the Dialer Interface dosent get an IP Address and never has but it does get a Default Route via the ISP is this common, Its been working fine untill recently.
add you sure you use
ip add nego
under the interface ?
also this x.x.x.x/ is the IP or hostname ?
if it IP it must then show in
show ip interface brief <<- with virtual interface
MHM
13 Replies 13
Hello
review this document
https://www.cisco.com/c/en/us/support/docs/long-reach-ethernet-lre-digital-subscriber-line-xdsl/asymmetric-digital-subscriber-line-adsl/71115-adslguide-pppoa-ts.html
Kind Regards
Paul
@paul driver
2w3d: Di1 IPCP: Install negotiated IP interface address 40.1.1.2
2w3d: Di1 IPCP: Install route to 20.20.2.1
I never see the install negotiated IP Interface address but do see the Install Route to x.x.x.x,
the Dialer Interface never gets an IP Address and never has. is this normal
Shut/no shut interface and check
Show ip interface breif
Sometimes it ISP dhcp issue not your router issue.
MHM
Run
Debug ppp nego
Then shut/no shut interface
Share debug here
MHM
@MHM Cisco World
VPN-Router-1#debug ppp authentication
PPP authentication debugging is on
VPN-Router-1#conf t
VPN-Router-1(config)#interface dialer 1
VPN-Router-1(config-if)#shu
VPN-Router-1(config-if)#shutdown
VPN-Router-1(config-if)#no shut
*Oct  7 15:14:20.462: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
*Oct  7 15:14:20.462: Di1 DDR: dialer shutdown complete
*Oct  7 15:14:20.466: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
*Oct  7 15:14:20.466: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
*Oct  7 15:14:22.462: %LINK-5-CHANGED: Interface Dialer1, changed state to administratively down
*Oct  7 15:14:32.588: %LINK-3-UPDOWN: Interface Dialer1, changed state to up
VPN-Router-1(config-if)#exit
VPN-Router-1(config)#exit
VPN-Router-1#
*Oct  7 15:14:41.738: %SYS-5-CONFIG_I: Configured from console by local on console
*Oct  7 15:14:42.702: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
*Oct  7 15:14:42.710: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
*Oct  7 15:14:42.710: Vi2 PPP: Using dialer call direction
*Oct  7 15:14:42.710: Vi2 PPP: Treating connection as a callout
*Oct  7 15:14:42.710: Vi2 PPP: Session handle[8A000007] Session id[4]
*Oct  7 15:14:42.754: Vi2 CHAP: I CHALLENGE id 1 len 77 from "bcf-aln2.wf"
*Oct  7 15:14:42.754: Vi2 PPP: Sent CHAP SENDAUTH Request
*Oct  7 15:14:42.754: Vi2 PPP: Received SENDAUTH Response FAIL
*Oct  7 15:14:42.754: Vi2 CHAP: Using hostname from interface CHAP
*Oct  7 15:14:42.754: Vi2 CHAP: Using password from interface CHAP
*Oct  7 15:14:42.754: Vi2 CHAP: O RESPONSE id 1 len 47 from "[email protected]"
*Oct  7 15:14:42.826: Vi2 PPP: Using dialer call direction
VPN-Router-1#
*Oct  7 15:14:42.826: Vi2 PPP: Treating connection as a callout
*Oct  7 15:14:42.826: Vi2 PPP: Session handle[2D000008] Session id[4]
*Oct  7 15:14:42.878: Vi2 CHAP: I CHALLENGE id 2 len 41 from "FB-LON05-CRI-LNS-001"
*Oct  7 15:14:42.878: Vi2 PPP: Sent CHAP SENDAUTH Request
*Oct  7 15:14:42.878: Vi2 PPP: Received SENDAUTH Response FAIL
*Oct  7 15:14:42.878: Vi2 CHAP: Using hostname from interface CHAP
*Oct  7 15:14:42.878: Vi2 CHAP: Using password from interface CHAP
*Oct  7 15:14:42.878: Vi2 CHAP: O RESPONSE id 2 len 47 from "[email protected]"
*Oct  7 15:14:43.902: Vi2 CHAP: I SUCCESS id 2 len 4
VPN-Router-1#
*Oct  7 15:14:43.902: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
Received SENDAUTH Response FAIL <<- let me check this error' it CHAP auth issue that why peer not get IP.
MHM
Show ppp all <<- share this please
MHM
@MHM Cisco World
VPN-Router-1.#show ppp all
Interface/ID OPEN+ Nego* Fail- Stage Peer Address Peer Name
Vi2 LCP+ IPCP+ CDPCP-            LocalT   x.x.x.x \
ip add nego
MHM
thanks fir the useful reply I checked again and contacted the ISP regarding your Interface comment
Hello
You should be seeing a route and a negoicated ip address , Looks like a possible authentication credential issue?
Have you verified the correct credentials with your ISP?  - hostname & password?
Can you post the following please?
sh run int  x/x  (physical interface used for PPP)
sh run | sec dialer
sh ip int brief
sh ip route
Kind Regards
Paul
@paul driver
Can I DM you that info ??
