difference between flashes
BartV1982
Visitor
Hi all
i have a Catalyst 6500
and i can't really find the difference between
sup-bootflash:
slavesup-bootflash:
bootflash:
slavebootflash:
the first 2 are for the 2 supervisors
but why would i need the last 2? and what are their functions when i have 2 supervisors?
Thank you
6 Replies 6
Leo Laohoo
Sup-Bootflash: is the flash of the HOT supervisor blade.
Slavesup-Bootflash: is the flash of the STANDBY supervisor blade.
Jerry Ye
Hi Bart,
In the supervisor card with MSFC, it contains two (2) components, switch processor (SP) and route process (RP). Switch processor provides L2 functions and route process provides L3 functions.
sup-bootflash: is the active switch processor's (SP) flash memory.
slavesup-bootflash: is the standby switch process's (SP) flash memory.
bootflash: is the active MSFC's (RP) flash memory.
slavebootflash: is the standby MSFC's (RP) flash memory.
In native mode, SP (L2) and RP (L3) are on IOS, IOS image doesn't need to be stored in bootflash: or slavebootflash:. The IOS image stored in sup-bootflash: and slavesup-bootflash: can boot up the both supervisor and MSFC.
If you are using hybrid mode, where the SP (L2) is on CatOS and the RP (L3)is on IOS, then the CatOS image will be stored in sup-bootflash: and slavesup-bootflash:, and the IOS image will be stored in bootflash: and slavebootflash:.
HTH,
jerry
its very good info:
but i am having hybrid version
i am getting this error
DC-6513-1> (enable) dir sup-bootflash:
Open device sup-bootflash failed (unknown devi
karthik
Hi Karthik,
In CatOS, there is no concept of sup-bootflash:, it use the device name of bootflash: or bootdisk: depend on which supervisor cards are in your Cat6500. Please see the following link for more info:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/configuration/guide/flash.html#wp1019835
HTH,
jerry
Hi Jerry
thank you for this clear explanation
i would say this topic can be closed but i see others still have some questions so i wasn't alone with questions 🙂
I have upgraded cisco IOS 12.2 to 15.2. after upgradating so many boot images view in boot variable command
why it is showing so many boot images showing?C4500-After upgrade so many boot images-1.jpgC4500-After upgrade so many boot images.jpg
