Disabling TFTP
arell1234
Community Member
I am trying to disable TFTP on my router but have had no luck. I have no tftp-server commands in the running config but I still seem to be able to connect to the router with a TFTP client. Is there anyway to stop the router from accepting tftp connections?
Ingress ACL or CoPP?
Hello
Following on from Vasilli comments, below are two examples for denying tftp to your router via CoPP and ACL
Router ip = 1.1.1.1/24
CoPP
access-list 100 permit tcp any host 1.1.1.1 eq telnet
class-map match-all notftp_cm
match access-group 100
policy-map notftp_pm
class notftp_cm
drop
class class-default
control-plane host
service-policy input notftp_pm
ACL
access-list 101 deny   tcp any host 1.1.1.1 eq telnet
access-list 101 permit ip any any
int x/x
ip access-group 101 in
res
Paul
Kind Regards
Paul
