DMVPN
srinivas12
Visitor
Hello Cisco,
DMVPN is not a cisco propreitary.? From my understanding it is but i have recieved views from others saying it is not. Can you please clarify my doubt.?
Srini
It is Cisco proprietary.
Other vendor use protocol same as dmvpn but no totally dmvpn
"""Cisco DMVPN (Cisco Dynamic Multipoint VPN) is one solution to this. Huawei also had their DMVPN-compatible solution called DSVPN (Dynamic Smart VPN). Since the protocol is largely compatible, I’ll just reference it as DMVPN"""
Thank you for the response.
In some way, both opinions are correct. DMVPN combines the three standard protocols IPSec, GRE and NHRP in a specific way. Although the three components are all established standards, the resulting DMVPN is not a standard. Every vendor could combine these protocol the same way, but for me the result is still a proprietary protocol.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
srinivas12
Visitor
Thank you for the clarification .
